I am finally close to completing my office desk, and it's top is going to be laminated cherry planks (3/4 thick). Since I have not yet glued them all together, I have the opportunity to put in a grommet for cables. I want to avoid the black/beige plastic stuff like this rectangular grommet, and now want to create something similar in the same cherry wood - so that the grommet is practically indistinguishable from the table-top.
Nothing to the design of it - I'm thinking I could just cut out a small 8 x 4 rectangular piece of one of the planks and re-affix it with a metal hinge.
But what hinge should I use? I want this to be concealed from the top, and as near seamless as possible.
I did find one option - the Soss hinge. My wood is only 3/4 thick, so I cannot use any hinge thicker than 1/2". Since this grommet will be nowhere as heavy as a door, I'm guessing this small hinge should suffice. My problem? Install looks like a lot of trouble - mortising an exact hole, etc! Isn't there an easier install option? Any suggestions?
The grommet is to going to be over a pedestal cabinet so the lower part is not going to be visible so I don't need to worry about aesthetics below the surface. I just need to be able to pull it open from above, and push it back down to close it.
