Don't do like I did. DC duct install flaw.
    • 9226
    I messed up thinking HVAC foil tape would have better longevity than it has... Which caused me a bit of a problem with my DC ducting... I show you the problem, and how I fixed it!
  • woodturner
    • Jun 2008
    • 2047
    • Western Pennsylvania
    Yes, that sealant tape doesn't have much structural strength. Gorilla tape or something like that may work better.
    Is there a reason you didn't just glue the PVC pipes together?
      • 1865
      Dave, I did the same thing, except I used duct tape instead of the HVAC tape, and worked ok but not as rigid as I wanted; my repair was the same - two screws at each joint, and then tape back over to seal. I tried PVC glue, but it didn't seem to work very well between the PVC fittings and the drainage pipe I used (that corrugated stuff.)
        • 9226
        I wanted easy access in case something gets jammed along the line.
          • 1865
          I found this out the hard way. After screwing and taping everything together, I was using my DustRight vacuum on the DC (which is connected to the end of the longest run for some reason...) to clean up around my lathe, where I keep one of those small containers with racquetballs (no, I don't play, but use them on occasion for supporing workpieces on the lathe.) Next thing I know, the DC has sucked up the plastic tube of balls (like a pneumatic tube system) through 90% of the line, including three 45 degree turns in the line, before it gets stuck at the fourth and final 45 turn - on the tip of one of those screws. Untape, unscrew, disassemble, remove, reassemble, re-screw, re-tape...
