I see LED shop lights are selling for around $50. 4 ft specs like 4100 deg K and 3200 lumens for 38 Watts.
So T8 dual 4' fluorescent fixtures you get (2 bulbs) 64 Watts and about 5800 lumens
But the lumens are omnidirectional so the "reflectors" are no where near 100% so the effective downward illumination is a lot less. The LEDs however are directed downwards so more efficient.
I guess you would need to compare lux and even then the patterns would vary greatly.
Does that make LEDs roughly twice as efficient? effectively similar outputs for 38 Watts compared to 64 watts?
Anyone using 4 foot LED shop lights and can offer a comparison?
I have 6 dual T8 fixtures so when I run the lights I have about 500 Watts... Costs me about a nickel an hour. LEDs would save about 2.5 cents per hour.
Relamping would cost about $300 bucks so payback in 12,000 hours...
3000 days or about 8 years at 4 hours per day
T8 bulbs have a lifetime of more than 20,000 hours compared with 50,000 hours for LEDs so that's not an issue for 12,000 hours.
http://www.premierltg.com/should-you...8-led-tubes-2/
Apparently you can get LED tubes that fit T8 sockets and operate with the ballast output making it very easy to swap and upgrade bulbs, The downside is you still use the ballast and have its inefficiency and reliability to deal with.
But $7.49 per bulb, $15 per fixture.
Is 5000 degK too stark white to use in the shop?
