Can anyone identify this tablesaw?
I'm with CWS, looks scary. Early table saws (pre 1950 era) were made like that. It might be ok if you were going to build a cabinet around it. 1/3 hp isn't squat for power so it would be a Bog-o-matic. Early saws didn't have blade tilt so that would be another disadvantage.Comment
Looks like an early AMT model, probably with an 8" blade.
You should be able to buy an older Craftsman in that price range and is likely a better option. Heck, I'll give you one if you will come get it. It's only 2000 miles or so away, unfortunately.
Electrical Engineer by day, Woodworker by nightComment
Table saws from the 40's and 50's often were sold as just a top and a elevating blade mechanism, even from the sears catalog..
You provided a base and a motor and a mount.
Of course, safety was about zero or slightly negative!
Often, only 7.5 or 8-inch blade, not the common 10 inch we see today.
There were several brands made like that. Sears sold some, AMT was another, Atlas yet another. I have a couple of friends that love them for trim saws, as well as model making saws. 8" blade sounds right.She couldn't tell the difference between the escape pod, and the bathroom. We had to go back for her.........................Twice.Comment
Pass is good. These old saws, just like the old "brick" cell phones were the forerunner to the saws of today. I wonder what table saws will look like in 50-60 years? The old saws tops were not as big as the the portable circular saw powered cheap saws so the top to this saw top wouldn't be much good as a donor for an extension to your Delta. For this application you would probably be better off purchasing the optional extension wing.Comment
Looks like the tag says Westinghouse. I have a 10" tilting table top TS w/ 6" jointer runs on a 220V motor made by Milwaukee/Rockwell, it has a blade guard, and I still got the original instruction sheets for it, it's about 60 to 70 yrs. old. Very solid (heavy), cuts straight but it needs to be reconditioned as I don't use it anymore. I got it from my late FIL who was a carpenter, I should sell it to someone who would want it for a project rebuild, just never got around to posting it on craigs list.Comment
Kick the wood stand out from under it, clean up the metal parts and spray a clear coat on them and make a greats coffee table or end table out of it by adding legs and a glass top. You can make a table out of nearly anything. The industrial look is really in now.Comment
Cool Idea!Comment
The photograph's resolution isn't good enough to be certain, but the tag sure looks like the motor is designed for 40 Hz AC! I've never seen one of those. 40 Hz began to be phased out (pardon the pun) over 100 years ago. It could be that companies made motors to operate from that frequency for many years. The motor will like turn faster than designed when connected to the modern 60 Hz line frequency, and there may be other effects, such as operating temperature, vibration, magnetic saturation in the core. Bottom line: capncarl has the only viable idea for its use!Comment
But that would be a rare line frequency and they didn't really start using "Hz" widely instead of cycles per sec until about 1965. This saw has to be older than 1965.
Finally the there's a row, where RPM says 1725 which would go with a induction motor on 60 Hz and the field to the right of 1725 says 60 which is probably the frequency even though we can't read the fine print. And next to the 60 its says 1 which is probably the phase. All three go together.
then 40 - what? I don't know.Last edited by LCHIEN; 06-24-2017, 03:16 AM.Loring in Katy, TX USA
1/3 HP, 1725 RPM, 60 Hz, 1 phase, 110V, 5.8A, 40 ºC, continuous duty.Comment
Footer Ad
