Jointer Blades
  • mcescher
    Handtools only
    • Apr 2018
    • 1
    Jointer Blades
    Not sure if this is the best place to ask this, but looked around and didn't really see any better place.
    I was gifted a used Tradesman 6 1/8" jointer (J1550W) from my dad. It has a chip out of the blades so it leaves a line on the wood. Is there a place to purchase replacement knives? I had seen another post where the answer to the OP was to just find some that looked the same. Can I just get some blades that are the same size and shape and be OK? Suggestions for sources?
    Thanks so much!
    Internet Fact Checker
    • 20968
    Measure them carefully and you may find some to fit, infinity has a line of replacement jointer blades.
    FOr the time being, you can often shift blades a bit to the sides. Presumably the blades have hit something hard to put a nick in them, try shifting one bade slightly to one side or the other (won't take very far) and then realigning the height and you may eliminate that line.
      • 3569
      Are these blades reversible? ( 2 sided )
        • 2740
        Grizzly Industrial carries a good variety of jointer knives which may be helpful http://www.grizzly.com/search?q=(6+A...nter+OR+knives)
        • jabe
          • 566
          • Hilo, Hawaii
          Usually all 6" knives are the same or inter-changeable. If what Lchien suggest don't work then U will have to sharpen or change the knives. When changing do not completely remove the hold down bar, just loosen the bolts/screws and lift the blades out slowly ( there might be springs under the knife ) and insert the new knife. Do one at a time usually will have 3 knives. Follow your instruction manual for setting and jointing the knives correctly before using.
          • mcescher
            Handtools only
            • Apr 2018
            • 1
            Thanks everybody, lots of good information.
