10 "Must-have" router bits by Shop Notes
    Internet Fact Checker
    • 20969
    Yes on 1,2,3,7,9. The other's I have not had occasion to use. The rabbeting bit would seem uber useful at first except that in my experience they don't come with a bearing kit.
      • 20969
      Buy the 6-piece kit with four bearing diameters. Perfect width rabbets!
      Or the 9-piece kit with 6 bearing diameters for 6 width rabbets.
        Yes, that reminds me of why I still have not bought thr kit.... Its nearly the same price as the router bit set! The bits are from mlcs.
          • 15218
          Bearing kits can be very useful especially if they fit a variety of bits. As for the rabbet bit, you may want to do rabbets with a straight faced bit...no bearing. The cutting profile (being vertical), may produce a better step. I do quite a bit of rabbeting with a straight bit and an edge guide (if doing handheld). On the table...just the fence.
            • 20969
            The good thing about rabbet bits with bearings is that the rabbet width is made virtually of perfect width by simply choosing the right bearing. Typically you can get 1/8, 1/4, 3/8, 1/2 3/16, 5/16, etc. which is half the difference of the cutter dia. and the bearing dia.
            If you are going to use a rabbet bit and be changing a lot of bearings, this bit vise may be of use: http://www.bt3central.com/showthread...outer+bit+vise
            • Knottscott
              • 3815
              • Rochester, NY.
              • 2008 Shop Fox W1677
              Hard to go wrong with those as your base set.
                • 2741
                I just bought a Bosch rabbeting bit (1/2 x 1/2) at my local Lowes a couple of weeks ago. Unfortunately it is a 1/4-shank, as they didn't have the 1/2-inch shank. I'm in the midst of making shutters for four windows in the library. Still messing around with my prototype though.
                I prefer a shear angle for rabbets, as opposed to a straight cutting edge. Just seems to give a nicer edge.
                • durango dude
                  • Mar 2011
                  • 934
                  Most useful in my experience:
                  - spiral up-cut (I use 1/4" - am thinking I'd like a 3/8")
                  - Rabbeting set (get a set with multiple bearings)
                  - Round over set (get a set - with interchangeable bearings - that way
                  the round-over set also functions as a bead set)
                  I used to use straight bits a lot until I tried a spiral bit ---- Man, I'm hooked.
                  For Mortises, the spiral up-cut seems to work much better for me.
                  I use my dove-tail bit some. Can't say it's impossible to do without, though.
                  Thanks to bt3central, I recommend
                  Whiteside router bits, Byrd shelix jointer and planer cutterheads, saw blades and other woodworking cutting tools from holbren.com
