Announcement
No announcement yet.
Decorative birdhouses
  • Filter
  • Decorative birdhouses
    Went into "mass" production on a birdhouse I made a couple of years ago.
    Decorative only, no birds can really fit into it! The interior is only 7/8" deep.
    Fisheye picture is my original commissioned by my wife, sort of adapted from an article in Lowes' DIY magazine.
    For a few relatives.
    The work on this spanned Hurricane Harvey one or two days either way. I almost thought it might never get finished as I comptemplated my garage shop being under water on the second and third and aftermath days of the hurricane,
    BT3 FAQ - http://www.sawdustzone.org/forum/dis...sked-questions
  • #2
    Loring,
    I like those. I bet it will make "practical" people (like me) do a double take: "How can a bird get in a house like that?"
    I'm glad to see that you are back in your home and making things.
    • #3
      Nicely done Loring - those are fun pieces, eyecatching.
      • #4
        Nice... I like that project, as it's attractive and what my wife would call "Cute".
        Thanks,
        • #5
          FWIW, this is what I needed the multiple short dowels jig for. See my other posts.
          • #6
            For those that are interested, here's how to make them.
            I just took some cedar fence planks 5.5" wide by 72" long, rough cut from the Lowe, or HD. They run 5/8 to 9/16 thick They last 10-15 years outdoors with no finish..
            Rip some 3-1/2" wide
            Resaw some 3.5" wide to 3/8" thick. This is for the tops and the fronts and backs.
            From the leftovers I ripped some 7/8" wide strips of the original thickness. You need as much of these as you do the fronts and backs.
            Make up several lengths of a rectangular assembly, the 3.5" x 3/8" on the front and back and the 7/8" sandwiched on the sides This makes a long rectangular tube that is 3.5" wide by 1-3/8" thick. I made the tubes about 30 inches long for ease of handling and that's enough for about 4 houses. I used glue and air pinner nails - I did cut some pins later but it's not much of a load on the saw blade to cut through pins.
            The first house has a 45 degree cut front to back. Note to make 4 houses you need to only make 2 45 degree cuts which saves a lot of wood (just flip it over)! The second house has two 45 degree cuts across the face; there's be some wastage here. The third house has a 30 degree miter cut and again, if you flip it you only need 2 angle cuts for four houses and no waste.
            I used my 12" miter saw but I think a 10" should handle these nicely as well.
            Now is a good time to drill the entry holes (7/8" dia) and the perch holes (3/16", 1/4" deep)
            Painted the fronts with a little acrylic pastel colors to give it a little pop.
            Now take another 3/8" thick by 3.5" piece for all the roof tops.
            The first house requires 3.5" wide. The 2nd and third houses need only 2" wide. Cut and bevel as in the pictures, leaving about 1/2" overhang. Glue and pin them in place.
            The width are somewhat critical but the thickness is not so its real easy to build.
            If you want them I can make a print of the front dimensions and the locations of the holes.
            The first set I built I built them one at a time. Some people said they liked the so for a while I've been thinking to knock out a few.- I figured how to make the tubes so it would go a lot faster. This is much easier t obuild 2 or 4 at a time and use the setups on teh saws and drill press.
            The "picket fence" base is just 1-1/2 inch wide 13.5" horizontals and 10.5" verticals.from cedar. Screwed from the back.
            • #7
              Loring,
              Those are really nice! Thanks for sharing. Also glad to see that you are safe and back at home.
              Turaj (in Toronto)
                LCHIEN commented
                Thanks, Turaj.
