Small (in size) mirror distributor needed
  • Bruce Cohen
    • 2698
    • Nanuet, NY, USA.
    I'm finishing my latest jewelry box and want to inset into the inside cover a mirror.
    What I'm looking for is something small (approx 5x8 inches with beveled ends.)
    Additionally, the box is in a *******ized Greene & Greene style and I'd like to get some etching on the mirror to emulate some of the inset floral designs that were commonplace to their furniture.
    Anyone out there have any leads. I've spent too many hours googling glass and mirror sites and still have nothing to show for it.
    Thanks,
    Bruce
    Samuel Colt did"
  • RAFlorida
    • 1179
    Bruce, I can not help you out
    for locating a vendor for your mirror. BUT, please post a picture of your "... *******ized Greene & Greene style..." jewelry box when you completed building it. Hopefully some of the other members will have a hit for you on the mirror.
      • 15218
      Something like these?
        • 5633
        I'd like to see it, too, Bruce. I just made a couple of boxes as a wedding present for a couple who have craftsman furniture. I couldn't think of an appropriate design, so I just used my latest concept. They liked the boxes, but they could have been a better match, IMHO.
        • herb fellows
          • New York City
          Have you tried stained glass suppliers? I know I've seen small mirrors at my local place, but I don't remember the sizes.
          • Bruce Cohen
            • 2698
            • Nanuet, NY, USA.
            Cab,
            That's great, just what I was sort of looking for.
            I guess I'll have to do the etching myself, which is no big dear (yeah right), got to contact them to see if they'll cut to size.
            BTW, Happy new year and don't eat too much chicken soup-lots of sodium.
            Bruce
            Samuel Colt did"
              • 15218
              Here's an option for you. Go down to your local drug store, Wally World, K-Mart or Target, and go to the section where the girls go for the pretty up stuff. There you will find hand mirrors in various sizes. They are usually 1/8" mirror and can be removed easily. They are either snapped in with a captive edge, or just hot glued in and can be released with a heat gun or hair blower from the back.
              You can cut the mirror to size real easy with a glass cutter. Take some air tool oil and mix in some mineral spirits to lighten it up a bit. Then use a clean brush and after you have cleaned the mirror lay a swipe line for where you want to cut. With the mirror face up, use a straight edge (if you want a straight line), and start the cutter away from you and rock the wheel on the edge. With slight pressure make one and only one pass to the other side without stopping, and come right off the edge. Hold the cutter like a pencil, with the three fingers past the index down to steady the cutter.
              You can likely just put the mirror between your fingers and thumbs on either side of the cut line and press back with a quick snap. IOW, the sides of the cut get forced back. Don't try to pull them forward. Or, just take the cutting tool (it may have a ball end), or the nose of a pliers and tap gently (behind where the cutter came off the glass) on the underside to start a crack, and the crack will follow the score line.
              You can soften the cut edge with silicone carbide sandpaper (wet-or-dry), either wet or dry with a 120x grit. Don't sand the back cut edge where the silvering is.
              Clean the mirror face, edge, and back and lay it on newspapers on a flat surface, face down. Spray the back and edge with a clear acrylic spray (not lacquer). That keeps the slivering from turning black as seen on the face. That happens because when the silvering is cut, it oxidizes from the edge.
              On the face, if you have a Dremel type tool, you can create your own engraving by using a small diamond bit shaped round, like a core box bit. You can draw out the pattern on the glass with a pointed grease pencil. Lay the running bit very gently onto the glass and keep it moving. The tool's balance should be almost neutral to the bit, so there isn't much pressure. You can create any pattern you want, just don't engrave off the glass. Keep all engraving within a border clear of the edge.
              Tell me how it works out for ya.
              • os1kne
                • 901
                • Atlanta, GA
                Very interesting info!
