Fence Tilt
  • ewelarry
    Handtools only
    • Jan 2018
    • 3
    • Moline IL
    • 3000
    Fence Tilt
    My newly purchased fence (BT3000) tilts towards the rear and does not slide smoothly. Any way to adjust this? Is the small wheel replaceable? Thanks
    • 1865
    Welcome! Can you show a picture of this tilt? Something sounds like its not seating properly. I have this problem when the clamper at the rear of the fence is on the rail instead of under it...
    • ewelarry
      Handtools only
      • Jan 2018
      • 3
      • Moline IL
      • 3000
      Will take a picture tomorrow. Thanks for responding.
        Internet Fact Checker
        • 20966
        Something Doesn't sound right. Either your front or rear rail are not mounted correctly, or, your rip fence is not mounted correctly. It should not tilt and there will be constant, small and even clearance between the bottom of the rip fence and the table top.
        • ewelarry
          Handtools only
          • Jan 2018
          • 3
          • Moline IL
          • 3000
          Mystery solved. The previous owner had the rear rail incorrectly installed. All is well. Thanks to all!
