BT3000 stuck.
  • Gbotha
    • Oct 2017
    • 20
    BT3000 stuck.
    Is this the culprit, and will this one work? Blade wont raise. Reading lots of info. Right now its just a big router table. I have the extension slides, with recessed router in the top.
    Just me
    • 8441
    More than likely. Probably 10% of the time it could be threads stripped in the raise / lower . And 90% of the time, it will be the shims in the link. You may need two shims; sometimes only one has fallen out. Never hurts to have an extra on hand.
    • joedad
      • Mar 2015
      • 24
      • Yardley, PA
      • Ryobi Bt3000
      I can lift the blade up and down by hand. It will not lift when I turn handle. Do you think the screw has stripped.
        Internet Fact Checker
        • 20983
        did you get the BT3 FAQ, using the link in my signature line below?
