Announcement
No announcement yet.
BT3000 blade won't tilt
  • Filter
  • BT3000 blade won't tilt
    i bought a bt3000 today and the blade height adjustment is very smooth however the blade will not bevel. I attempted to un assemble the tilt piece and it still is not working? Does anyone know how to correct this issue? Thank you
  • #2
    If it won't tilt but does raise and lower OK, then it is "probably" in the mechanism. I can't imagine that the previous owner removed the bevel "gears", but that did come to mind. Below is a link to a thread that that deals with another aspect of bevel problems - namely controlling the bevel set. It might help. If some things are in the wrong orientation, then you could have your problem. It does seem like the previous owner may have tried to adjust it and didn't know what he was doing.
    http://www.sawdustzone.org/forum/dis...ted-and-solved
    Read all the way to the end. It was about half way through that I actually discovered the specific problem.
    • #3
      Can we have a few more details on what your saw does when you try adjusting the bevel? For example, when moving the lever to the left (to switch to bevel adjust mode) how far does the lever go? What does the main adjustment handle do - is the blade still going up/down instead of tilting, does the handle wheel just spin uselessly, or does it feel jammed?
      Switching to bevel adjust is a "sequence" of sorts in the saw mechanicals... just trying to see where in the process your saw is struggling. Many times it's simply the lever isn't moved far enough to the left to engage a final piece of the sequence. On my saw, the lever takes a bit of force to "break free" from the normal height adjust position, then it's fairly easily moved (as if it's not connected to anything) for much of the clockwise rotation, then in the final inch or two of travel I can finally feel it doing something. If I don't get it all the way to the left, the main handle wheel does nothing.
      mpc
      • #4
        The problem is the spring that sits between the tilt gear and shaft to adjust the height. It was all bent up, I removed it and the bevel works smooth and there's a little play in the height adjustment. Where can I get a replacement one and what's the procedure for replacing this spring? I removed it with wire cutters, because the pin was hung up on it. Thank you again!!
        • #5
          I have a picture but it won't let me send it. It says unauthorized for attachments
          • #6
            Cody, I got your message. What you need is a new spring.
            I have some ebay links below
            Whole set http://www.ebay.com/itm/Blade-Adjust...UAAOSw~XpZVN7b
            This one looks to be the best for your situation -> Spring only: http://www.ebay.com/itm/Ryobi-Spring...MAAOSww3tY3dYi
            spring and parts: http://www.ebay.com/itm/Ryobi-BT3000...QAAOSwe7BWw-Rc
            • #7
              Cody, I think your posts must be approved until you reach either 3 or 5 posts and then it will show up automatically.
              • #8
                Hello Hank, thank you for the reply I'm ordering the part now. How do I replace it? Thank you again for all your help!
