I have a BT3000 with early-generation motor. The hole in the motor housing that marries up to the elevation screw (worm gear?) stripped completely. Anyone have a line on the parts to make a helicoil repair to this?
BT3000 Elevation Mechanism Stripped
I repaired one of mine a couple years ago, after I got tired of replacing the worn out Helicoil. Has been fine since then, no sign of wearing out.--------------------------------------------------
Electrical Engineer by day, Woodworker by nightComment
I like the "permanent" repair option. Since you've made the repair in the past, can you verify that the elevation screw is a 9/16-12? And I assume the Timesert option would require that I purchase the entire kit including the drill bit, tap, insert tool, insert, etc. in order to be able to do the repair?
I will need to dig out the kit to verify, but will do so. Unfortunately there is a cost premium to the TimeSert kit, so depending on how much you use the saw, the Helicoil may be a reasonable option. You may also be able to find the replacement piece on Ebay or another source for less than the TimeSert kit, just make sure it is the correct one.--------------------------------------------------
The complete kit including the insert, drill bit, tap, counterbore and insert tool for 9/16-12 is $128, but the inserts without the tool kit to go along are $3.41 each. Its my understanding that everything except the counterbore tool are standard tools, I may have to go back and buy the kit, but I've got access to tools, and am going to try it without buying the kit of tools first. I'll let you know how it goes.
Their solid inserts look like they would work as well as a TimeSert, and using standard tools for installation is a huge plus. Wish I had known about that option when I did my repair. Do any of the box stores carry them?Last edited by woodturner; 01-19-2017, 07:06 AM.--------------------------------------------------
Footer Ad
