I've had a BT3000 that I bought off craigslist for a couple years now. It's been serving me pretty well.
I have an issue, though. The splitter was missing when I bought it, so I bought one off a parts store. When I went to install it, the splitter didn't line up with the blade. I think this is because the arbor is out of alignment with the guide holder. From the perspective of someone standing at the table saw as if they're using it, the rear of the blade is pretty far over to the right, so it doesn't line up with the part of the guide holder that the splitter is bolted against. There are some shims where the splitter is installed that would help if I had the opposite problem, but nothing to help with my problem.
For a while, I went with the easy solution, which was to shim the blade to the left with a couple arbor shims that add up to ~30 thousandths (in addition to the .5" and .25" arbor shims). This isn't an ideal solution, because it reduces the amount of unthreaded arbor for the blade to seat on, but there is still enough and it has worked okay-ish.
However, I'd like to fix it. Having the blade that far out of alignment means that the miter slot table would need to be that far out of alignment, and I'd just as soon have the miter slot table register against the the saw table without any fuss. Has anyone else had this issue and fixed it?
