Announcement
No announcement yet.
BT3000 Bevel Jump Issue Revisited (and solved?)
  • Filter
  • #16
    The correct order of the videos is:
    https://vimeo.com/242179527
    https://vimeo.com/242179388
    https://vimeo.com/242179258
    Thanks,
    Kirkg
    • #17
      Originally posted by Kirkg View Post
      I got to look at them. Mine used to do that - jump back and several others did also.
      1. Is the set screw tight?
      2. Is the large nut behind the handle snug?
      My set screw wasn't terribly loose, but I tightened it, anyway. The large nut behind the handle (against the body of the saw) was VERY loose--almost falling off. I snugged that up (had to back it off, I tightened it too much at first) and put everything back together per Hank's GREAT instructions.
      • #18
        Hi Hank-
        Yes- I tightened the set screw in the lever tight on the large nut.
        Regarding the large nut- I have it tightened so that the lever only needs to be pushed to the left and that tightens the large nut onto the slot.
        • #19
          The only other thing I can think of is to crawl under and watch the backside from up under as you release the lever and see what is jumping. I did that a couple of times, but my problem was not there. It seems like something behind the front panel might be loose.
          • #20
            I think I fixed it. I loosened the 3 screws holding the gear rack and pushed it down as far as the screw holes would allow and then tightened the screws. It how operates smoothly. I show 3 pics of this and 1 pic of what the gear rack looks like in a BT3100.
            Thanks much.
            Kirkg
            • #21
              I don't remember seeing this problem. THANKS for posting the problem and solution! It will probably be a help to someone else.
