I want to make my own zero clearance inserts for my BT3000, but the ends of the insert have to be so thin at each end to be level with the table, that there is not enough wood left to hold the screws effectively.
I see that there are 4 "tabs" located lower in the cavity, that appear to be threaded ... does anyone know what size screws fit into those holes ... it would allow for more thickness to hold the screws
Any advice would be appreciated ... thanks in advance
