so, i was building some subwoofer cabinets and i started to get some on and off and i jiggled the motor ac cord and it would restart, three quarters the way thru the project it was dead. read the forum and it was suggested to plug the motor straight to power to determine if it was a switch problem or a motor problem. well, i'll be dipped....straight to power and nothing from the motor. it is a near first gen model so i suppose not too surprised, but i was not dogging it and i smelt no giveawy burn smell. so, i checked a bit and i am not finding too much on the motor replacement or if there are still shops that will rebuild... suggestions?
motor thoughts, maybe replaced
if there's no burnt smell you may not have toasted the windings.
Did you check the brushes at all? The brushes may be hard to get for the older saw but you can actually make some.
Check continuity of wiring and connectors.Last edited by LCHIEN; 12-26-2014, 01:33 AM.Loring in Katy, TX USA
BT3 FAQ - https://www.sawdustzone.org/forum/di...sked-questions -
Incidentally the early motor housing (#18) certainly appears to have been leveraged from what was a current production left-hand side blade sidewinder circular saw, given the unused pivot arm molded into the housing. I seem to recall motors in several saws at that time to have been marketed with a "13A motor" feature bullet.Comment
Footer Ad
