I picked up a BT3000 a few months back from friend, that has not beenused it a couple of years. I stumped on this problem I was thinking the shims were bad becase the blade had trouble rising. I opened it up cleaned it out, (not much to clean though) The shims are correct and in the right position, ( they have not slipped out of postion.)
I removed the shims. The shims looks ok, not bent or anything. It looks like they are new shims. I checked all the gears for the blade rise to see if it was stipped ;everything looks ok as far as I can tell.
I assembled the saw and it still has a little struggle moving up and down, not as much though. I pick up the motor with my hand to help it along, so as the screw for the blade rise does not stip. I have read the board on this problem for the last week.
I'm stumped here guys, what am I missing here.
I
I
