Does anyone know of a good replacement fence for the BT3001?
rip fence
Originally posted by josephlorDoes anyone know of a good replacement fence for the BT3001?
Although a few people do have problems with their fence (as with any brand) it is one of the best and most accurate stock fences on the market. It does have one set up feature that drives some people nuts until they realize that is part of the set up. It has a two step locking and it swings straight into alignment just before clamping in the rear.
At that point it is clamped in the from and in the rear. Solid.
There was a fence made two or three years ago as a replacement but it cost a good bit and was not any better than the OEM fence.Hank Lee
Experience is what you get when you don't get what you wanted! -
There have been several threads regarding this issue, so it might be worthwhile having a trawl around and seeing if any existing thread replies solve your problem. A common symptom is failing to lock correctly and is often solved by sorting out the location of the clamper in the rear rail.
To get it to locate properly, the adjusting screw needs to be slackened and the whole fence lifted at the front to an angle of around 30 degrees, so that the clamper pops in under the innermost top shoulder of the rear rail extrusion. The side-view diagram below shows the correct location in picture "B" (clamper in black, rail section in gray).
Picture "C" in the diagram shows the location that causes most problems, often accompanied by an inability to get the handle down past horizontal.
Once correctly in place, the adjuster screw can be wound right in, then slackened to adjust the position of the operating handle to your taste. Mine locks the fence just below horizontal, which is how I like it. Others prefer a little more, so slacken the adjuster accordingly.
If this is not the problem, let us know what drove you to ask about a replacement fence - maybe together we can sort yours out.
Ray.Did I offend you? Click here.Comment
Footer Ad
