Am I missing something? Is there a way to lock the smt in place so it doesn't slide while ripping a board? Should I just swap the SMT table with the acc. table?
SMT While Ripping?
Yes there is the front tab, but I found out over years of use mine dont lock too good and mine slides during ripping too.Comment
Originally posted by davidtuOn a related note, why are there two slots for that SMT lock?
IF you flip the SMT into the reverse position so that the base/track is sticking out in the rear, then the first slot allows the SMT to align up in this position with the front of the main table front.Hank Lee
Experience is what you get when you don't get what you wanted!Comment
Originally posted by John HunterThe tab is part number 13 on this diagram, it locks into either of the slots shown by the red arrow.
[ATTACH]2386[/ATTACH]
as stated by another poster the two holes are for lining up with the SMT in the normal and reversed positions.
I've never had any problem with mine slipping, it's a very reliable, simple mechanism.Loring in Katy, TX USA
Footer Ad
