Announcement
No announcement yet.
Need some wiring help. Calling on EE (Loring)?
  • Filter
  • Need some wiring help. Calling on EE (Loring)?
    I bought a sliding gate opener and separately an Infared sensor. The opener installed pretty easily and works great but I can't figure out the infrared. I can't even get it to turn on. It seemed easy but I must be doing something completely wrong. Below is the schedmatic for the Infrared and gate opener. Can someone please explain how to wire this. I tried so many configurations and still got nothing. Initially when I first opened the gate opener panel there was a wire that directly connected the IR terminal to the Gnd. I tried with it on and off. Attached is also the current state of how I wired it. Assuming I didn't get a defective infrared (how can I test for this?) or the gate opener is putting out the necessary power (still waiting on a replacement multi-meter), what am I doing wrong?
    sorry for the messy instructions. It got stepped on a few times
    Gate Opener Diagram Gate Opener Diagram Current configuration
  • #2
    Connect:
    GND to COM
    BROWN to 24 VDC
    BLUE to COM
    GRAY TO IR
    WHITE TO COM
    BLACK is not connected
    • #3
      Thank you Thank you Thank you. Tried it out as soon as I got home and it finally turned on. I spent a few hours this weekend trying to figure this out. Trying different configurations. Didn't realize you had to put the other power wire (blue) to com as well. For the electronically illiterate, like me, why is that?
      • #4
        Brown and blue are power to the device. With the blue disconnected, it had the +24 V but not a return path, so the device was not powered and would not operate. For electricity to flow, a complete circuit is required, it needs an "out" and an "in".
        • #5
          sorry late to the party - glad you got it fixed.
          BT3 FAQ - http://www.sawdustzone.org/forum/dis...sked-questions
          • #6
            Is there any reason I couldn’t add a second sensor. I currently have it set low so my dog would trigger it if she walked passed but realized my truck won’t trigger it till my wheels get psssed. I was thinking of adding a second one higher up.
            • #7
              You can add a second sensor, wire it is series:
              (keep the GND to COM - only need the one connection at the board)
              On the second sensor:
              BROWN to 24 VDC
              BLUE to COM
              Disconnect the WHITE TO COM on the first sensor, connect the white wire from the first sensor to the GRAY wire on the second sensor, connect WHITE TO COM on the second sensor
              BLACK is not connected on both sensors
