When you have too much stuff the failure rate starts to approach the frequency of use.
Went to the shop this last night to cut a piece of wood to repair the potting bench shelf that my wife overloaded with a bag of gravel.
The remote switch for the Dust collector wouldn't work. The fob blinked; that told me it had a good battery.
After I cut the wood I checked out the DC, fortunately it worked but the remote relay box I built did not... the remote control AC switch was bad.
Like a dutiful EE I opened it up to see what I could do, I did find the circuit board got real hot around what appeared to be the power supply part of the little board. I checked near the charred diodes and found that they had seriesed two diodes in one diode component location and that both were shorted...
I could replace the two diodes but there's no guarantee that was the original causal failure.
Amazon had a AC remote switch for $11. shipped.
WIth my consulting rate I could buy a lot of those for an hours work,. I just ordered a new one.
So to the original premise, can you have so much stuff that every time you turn something on there's a good chance something related in your shop has broken? Are you on perpetual maintenance then?
