pocket blow gun
this is the shortest review for the cheapest tool on BT3Central.
I was wasting time at HF the other day so I bought a pocket blow gun 68262 a slim blow gun
for the grand price of $1.89 (So this has to be a record low price for a reviewed item here, right?)
I figured it would be handy.
But, there's no trigger so it blows all the time. At least, it would if the industrial connector machined into it actually fit. I could not lock it to any of the several quick connects I tried to mate it to. Theoretically screwing the front knurled part into the main body regulates the amount of air flow. I never really got to try out that feature.
PS mine was not brass-colored body like the one in the picture. The pocket clip may well be the best feature (sad, really)
It's going back. HF loser.Posting comments is disabled.
Categories
Article Tags
- BT3x00 (71)
- bt3000 (5)
- bt3100 (2)
- diy (2)
- dust collection (11)
- Fence Attachments (12)
- fence clamps (1)
- General (5)
- Hand Tool Accessories (3)
- Hand Tools (14)
- Measuring & Layout (6)
- miter fence (3)
- Mobile BT3x00 (9)
- Mobile Tools (9)
- Other Reviews (4)
- Other Tools (5)
- Power Tool Accessories (28)
- Power Tools (75)
- rails (3)
- rip fence (5)
- safety (5)
- Sharpening (4)
- t-nut (3)
- wide table kit (2)
Latest Articles
by twistsol
Summary
Channel: Tool Reviews
03-23-2022, 02:59 PM -
by LCHIENI have always had trouble mounting small hardware on small wood boxes, with the hasps and hinges always looking slightly off perfectly square - particularly a problem with flat head screws and countersunk hardware which aligns the hardware to the hole location and centers on the hole.
08-30-2021, 12:18 AM -
by twistsolSince my new shop is in the basement, dust collection is a bit more important than when I had my own building and could do as I pleased in the shop. With that in mind, I upgraded the dust collection on my table saw. I purchased the Grizzly Overarm Blade Guard to use with the saw.
07-26-2021, 03:47 PM -
by twistsol
03-19-2021, 05:57 PM -
by LCHIENHere's a tool I found useful for marking. Accutrax pencil blade marking knife.
01-14-2021, 03:25 AM -
by LCHIENHey, I'm sharing one of my favorite tools. A Veritas Saddle Square. Actually I have two in different sizes. This is the large size for marking 2x4 and 4x4 (shown on 4x4 here). One of those tools that makes woodworking a pleasure.
01-13-2021, 02:20 AM -
The SawdustZone Statistics
Topics: 61,290
Members: 20,633
Active Members: 68
Welcome to our newest member, Foster Kingston.
What's Going On
There are currently 6395 users online. 4 members and 6391 guests.
Most users ever online was 11,606 at 02:28 AM on 03-29-2024.
Footer Ad
I've found HF air fittings to be really hit or miss on quality. The blow guns mostly seem fine, but the female quick connect fittings I've tried are junk, and break easily if dropped.
YMMV.
I guess I would have figured it out if I had been able to connect it to the quick coupler. unfortunately it didn't. I tried it on a few loose couplers and it wouldn't mate either. Looking at it the dimensions appeared to be off a little.
