Harbor Freight pocket hole jig
Has anyone here tried the HF pocket hole jig # 96264 as yet? I saw one in their local store the other day and decided to try one....on sale for $49.99 down from the usual $69.00. I haven't actually used it on a real project as yet , but have made a couple of test cuts and joints using the jig on some scraps and it works surprisingly well so far!
Good points: (1) 4 different drilling positions for the pocket holes in different thickness of stock. (2) good quality, adjustable stock holding clamp (3) a good step drill bit with stop collar and allen wrench, (4) width adjustment for spacing of pocket holes, (5) solid overall construction, (6) clear instructions included, (7) hardened drill guides for the step drill bit.
Bad points: (1) long screw bit not included with the tool, (2) supplied screws
are hex head and may " cam out" easier if proper pressure is not used during
installation into pocket hole, (3) a better temporary mounting flange should have been cast into the rear of tool for use of c- clamp or vise grips.
I hope this mini-review/ mini-gloat helps someone who is contemplating
buying a pocket hole jig and needs a good quality item for a decent price.Posting comments is disabled.
Categories
Article Tags
- BT3x00 (71)
- bt3000 (5)
- bt3100 (2)
- cordless (1)
- diy (2)
- dust collection (11)
- Fence Attachments (12)
- General (5)
- Hand Tool Accessories (3)
- Hand Tools (14)
- Measuring & Layout (6)
- miter fence (2)
- Mobile BT3x00 (9)
- Mobile Tools (9)
- Other Reviews (4)
- Other Tools (5)
- Power Tool Accessories (28)
- Power Tools (75)
- rails (3)
- rip fence (4)
- safety (5)
- Sharpening (4)
- t-nut (3)
- wide table kit (2)
Latest Articles
by twistsol
Summary
Channel: Tool Reviews
03-23-2022, 02:59 PM -
by LCHIENI have always had trouble mounting small hardware on small wood boxes, with the hasps and hinges always looking slightly off perfectly square - particularly a problem with flat head screws and countersunk hardware which aligns the hardware to the hole location and centers on the hole.
08-30-2021, 12:18 AM -
by twistsolSince my new shop is in the basement, dust collection is a bit more important than when I had my own building and could do as I pleased in the shop. With that in mind, I upgraded the dust collection on my table saw. I purchased the Grizzly Overarm Blade Guard to use with the saw.
07-26-2021, 03:47 PM -
by twistsol
03-19-2021, 05:57 PM -
by LCHIENHere's a tool I found useful for marking. Accutrax pencil blade marking knife.
01-14-2021, 03:25 AM -
by LCHIENHey, I'm sharing one of my favorite tools. A Veritas Saddle Square. Actually I have two in different sizes. This is the large size for marking 2x4 and 4x4 (shown on 4x4 here). One of those tools that makes woodworking a pleasure.
01-13-2021, 02:20 AM -
The SawdustZone Statistics
Topics: 61,270
Members: 20,614
Active Members: 74
Welcome to our newest member, Havoily.
What's Going On
There are currently 10772 users online. 3 members and 10769 guests.
Most users ever online was 11,606 at 02:28 AM on Today.
Footer Ad
The HF jig looks pretty good. I've got two from Kreg and they are well-built and designed. I also have their shelf pin jig which is really nice. I used mine after a cabinet was built, and it was easy to use.
dbhost commented
My next step is to make a platform for the jig and a box to hold the small pieces. (Boxes of pocket screws, step bit, hex wrenches, square drive driver etc...)
