Chicago Electric 69820 Initial impressions.
  • Chicago Electric 69820 Initial impressions.
    I needed a way to knock down floor leveling compound for my concrete patch and staining project, and I figured a disposable belt sander would be workable. I wanted to get a sander that shared belt size with my Ridgid EB4424.
    Upon unboxing and inspection, I found it to be much heavier than I felt the demo model at the store was. I plugged it in and took a test pass at some exceedingly high leveling / patch compound in my floor...
    I plugged it in, and pulled the trigger, watching the belt tracking. With zero adjustments, I watched the belt tracking for about 45 seconds as it ran, and found it to be exceptionally smooth and clean tracking.
    I tackled some rough spots of level compound and it made quick work of the uneven spots, which also showed very rapdily where this sander fails. Dust collection. To call it abysmal would be to compliment it. The port / bag might as well not exist. But for $52.00 after coupon, what do you expect?
    So far I think this will do the job I need it to do. If it breaks when I am done with this project, I won't likely care...
    • rcplaneguy
      rcplaneguy commented
      Thanks for the review.
      I bought one of the Chicago angle grinders for a similar project. It works fine, no problems. Remarkably inexpensive.
      dbhost
      commented
      With this particular tool, I will be happy if it lasts through the 90 day warranty period. I bought it to be disposable. I have one job in mind for it. if it lasts like my other HF power tools have, I honestly will get sick of it before it dies...
    Posting comments is disabled.
Latest Articles
  • A review of the Kreg Precision Trak & Stop Kit
    by twistsol
    Summary
    03-23-2022, 02:59 PM
  • Review of VIX-type Self Centering drill bits
    by LCHIEN
    The problem comes about with small bits like 1/16 and 5/64 and 3/32"...
    08-30-2021, 12:18 AM
  • Grizzly Overarm Blade Guard review.
    by twistsol
    First impressions were that this is an extremely solid and well built unit. It's made mostly of steel and connects to a 4" DC hose. There were a number of issues getting it set up and installed, and a...
    07-26-2021, 03:47 PM
  • Kreg KMA 3220 5mm Shelf Pin Jig
    by twistsol
    I decided to look for the rock bottom cheapest 32mm drilling system available that would let let me create real 5mm holes spaced 32mm apart, that was easy to use, and didn’t require a bunch of setup time. I’m really surprised at how much I like this little Keg jig especially when you consider the price of $34.99, and it has everything included. There were a couple of jigs cheaper but you needed to buy a self-centering 5mm bit to go along with them so they would...
    03-19-2021, 05:57 PM
  • Knife marking pencil Accutrax
    by LCHIEN
    Here's mine. I have not broken it, it seems to be quite sturdy. The sharp edge lasts a long time. I'm still on the...
    01-14-2021, 03:25 AM
  • Saddle squares
    by LCHIEN
    Works really well when the board has a rounded edge or some wane where the edge is not really sharp and square but the two adjacent faces are square to...
    01-13-2021, 02:20 AM
The SawdustZone Statistics
Topics: 61,283   Posts: 558,546   Members: 20,626   Active Members: 66
Welcome to our newest member, pablosala.
What's Going On
There are currently 3084 users online. 2 members and 3082 guests.
Most users ever online was 11,606 at 02:28 AM on 03-29-2024.
