HF Air impact screwdriver Central Pneumatic #90059
On a lark I bought this from HF for $14.39 (17.99 less a 20% off coupon), it's currently still $17.99.
http://www.harborfreight.com/air-too...0059-2156.html
I have a couple of cordless impact drivers, one 12V from B&D and the other a 19.2V Craftsman C3; keeping batteries is an expensive proposition. The advantages of an impact driver have been discussed before, notably driving high torque screws by impact rotation which is different than constant torque drill drivers for driving screws and fasteners which require you to provide reaction torque holding the tool. The impact tools use a large number of small impacts balanced by the mass of the tool, it drives much more efficiently and comfortably and avoides breaking the fastener.
Anyway, the air impact driver has a 1/4" hex drive like my cordless impact drivers, and runs off my air compressor so is available for those driveway construction projects without worrying about battery life or even if the batteries are any good. For a whole lot less dinero (That's Texican for money) than the cost of a battery pack and or a cordless driver.
Comes with a male QD air connector and a double-ended slot/phillips bit. I ran mine on a 6 gallon pancake air compressor and a 50-foot 1/4" PU hose.
Seems to work quite well as my cordless impact drivers but I only drove a few screws this past weekend. A bit noisy you have the cool-sounding air tool motor sound as well as the impact sound. Probably in net a bit louder than cordless. Finish is as good as or better than average for HF tools which is say its OK.
Specs say 15 ft-lbs, 8000 RPM (probably impacts per min) and 6CFM. My compressor is less than 6 CFM, but I think it'll be OK since you don't generally use a driver 100% of the time so the tank can store some air.
It has a knob to select direction (L&R, R being CW and L being CCW) and another knob for setting torque which is something even my cordless drivers don't have.
I guess in further testing the torque of this is limited. Spec'ed as 15 ft-lbs which is 180 inch-pounds. MY C3 driver is rated 1500 in-pounds.
The air driver won't put a 2" screw but halfway into an not-pilot-drilled piece of wood. I think my C3 will when working, but right now I have three dead batteries that won't hold a charge long enough for me to test... My B&D impact driver has two battery packs died of old age. Which sort of makes the air tool a winner by default.
But disappointingly low torque for the PSI and air flow.Last edited by LCHIEN; 06-28-2022, 02:42 AM.Posting comments is disabled.
Categories
Article Tags
- battery-less (1)
- BT3x00 (71)
- bt3000 (5)
- bt3100 (2)
- diy (2)
- dust collection (11)
- Fence Attachments (12)
- General (5)
- Hand Tool Accessories (3)
- Hand Tools (14)
- Measuring & Layout (6)
- miter fence (3)
- Mobile BT3x00 (9)
- Mobile Tools (9)
- Other Reviews (4)
- Other Tools (5)
- Power Tool Accessories (28)
- Power Tools (75)
- rails (3)
- rip fence (5)
- safety (5)
- Sharpening (4)
- t-nut (3)
- wide table kit (2)
Latest Articles
by twistsol
Summary
Channel: Tool Reviews
03-23-2022, 02:59 PM -
by LCHIENI have always had trouble mounting small hardware on small wood boxes, with the hasps and hinges always looking slightly off perfectly square - particularly a problem with flat head screws and countersunk hardware which aligns the hardware to the hole location and centers on the hole.
08-30-2021, 12:18 AM -
by twistsolSince my new shop is in the basement, dust collection is a bit more important than when I had my own building and could do as I pleased in the shop. With that in mind, I upgraded the dust collection on my table saw. I purchased the Grizzly Overarm Blade Guard to use with the saw.
07-26-2021, 03:47 PM -
by twistsol
03-19-2021, 05:57 PM -
by LCHIENHere's a tool I found useful for marking. Accutrax pencil blade marking knife.
01-14-2021, 03:25 AM -
by LCHIENHey, I'm sharing one of my favorite tools. A Veritas Saddle Square. Actually I have two in different sizes. This is the large size for marking 2x4 and 4x4 (shown on 4x4 here). One of those tools that makes woodworking a pleasure.
01-13-2021, 02:20 AM -
The SawdustZone Statistics
Topics: 61,286
Members: 20,629
Active Members: 64
Welcome to our newest member, buildergenius.
What's Going On
There are currently 5082 users online. 3 members and 5079 guests.
Most users ever online was 11,606 at 02:28 AM on 03-29-2024.
Footer Ad
