Central Machinery model 32208 4 speed 14" bandsaw initial impressions.
The Central Machinery Model 32208 4 speed 14" band saw, and its single speed sibling the 32206 (only difference appears to be the pulley setup), can be an amazing band saw bargain. I purchased mine with a markdown from $329.00 to $299.00, and then used a 15% off any one item in store coupon to get the saw at $255.00 + tax. Aside from a well used saw, even 10" saws are hard to come by in that price...
The overall fit and finish of the saw ABOVE the stand appear to be on par with the bottom end Grizzly 14", the Ridgid BS1400, and lower model Delta 14" saws. The main difference that I can see is features (2" instead of 4" DC chute, 1HP instead of 3/4HP motor, etc...). The BIG difference is where / how the motor mounts. (The CM mounts UNDER the stand, the Ridgid for example mounts behind the saw frame on the stand).
Assembly of this saw is NOT an easy task, as the documentation is written initially by somebody that does not speak English as their native tongue, and to make things worse, they simply leave out LARGE sections of the assembly instructions. Plain and simple, have good mechanical skill going in, ask a lot of questions, and if need be, use the Harbor Freight tech support number....
The motor bracket is shown mounted BACKWARDS in the instruction sheet. Both the printed one, and the one online. There are minimal instructions for setting up any of the safety guards, and you can only sort of hit and miss guess at where they are supposed to go... And the blade guides are a quirky design...
As far as I know, even Powermatic band saws need some tweaking from the factory to work their best, and the Central Machinery saw is no different. It needs a much improved blade like almost every other saw on the market, as well as a decent fence, rise block kit if you are going to do any serious resawing, and at a minimum the OE blade guide blocks should be replaced with Olson Cool Blocks as soon as possible.
The tension adjuster is a simple knob, as is the tracking adjuster.
After the headaches and a few unneccesary cuts from the poorly finished metal edges (typical of Chinese construction) the saw is together.
The blade appears to be tracking straight with a home brewed sled.
As a test I cut some curve shapes out of a 3" Oak Plywood glue up / waste that was in the workshop. The saw was on the highest speed setting, and did not bat an eyelash at going through this material even with the poor quality stock blade.
I expect many years of good service out of this saw. It is much smoother than I expected out of an HF saw, and it operates quietly.
So far I feel this has been money well spent. Ask me in two years if I am still happy I spent the $$ on it and we will see!Posting comments is disabled.
Categories
Article Tags
- BT3x00 (71)
- bt3000 (5)
- bt3100 (2)
- diy (2)
- dust collection (11)
- Fence Attachments (12)
- General (5)
- Hand Tool Accessories (3)
- Hand Tools (14)
- Measuring & Layout (6)
- miter fence (3)
- Mobile BT3x00 (9)
- Mobile Tools (9)
- Other Reviews (4)
- Other Tools (5)
- Power Tool Accessories (28)
- Power Tools (75)
- rails (3)
- rip fence (5)
- router (1)
- safety (5)
- Sharpening (4)
- t-nut (3)
- wide table kit (2)
Latest Articles
by twistsol
Summary
Channel: Tool Reviews
03-23-2022, 02:59 PM -
by LCHIENI have always had trouble mounting small hardware on small wood boxes, with the hasps and hinges always looking slightly off perfectly square - particularly a problem with flat head screws and countersunk hardware which aligns the hardware to the hole location and centers on the hole.
08-30-2021, 12:18 AM -
by twistsolSince my new shop is in the basement, dust collection is a bit more important than when I had my own building and could do as I pleased in the shop. With that in mind, I upgraded the dust collection on my table saw. I purchased the Grizzly Overarm Blade Guard to use with the saw.
07-26-2021, 03:47 PM -
by twistsol
03-19-2021, 05:57 PM -
by LCHIENHere's a tool I found useful for marking. Accutrax pencil blade marking knife.
01-14-2021, 03:25 AM -
by LCHIENHey, I'm sharing one of my favorite tools. A Veritas Saddle Square. Actually I have two in different sizes. This is the large size for marking 2x4 and 4x4 (shown on 4x4 here). One of those tools that makes woodworking a pleasure.
01-13-2021, 02:20 AM -
The SawdustZone Statistics
Topics: 61,290
Members: 20,633
Active Members: 67
Welcome to our newest member, Foster Kingston.
What's Going On
There are currently 9321 users online. 2 members and 9319 guests.
Most users ever online was 11,606 at 02:28 AM on 03-29-2024.
Footer Ad
Iturra Design is in Jax, FL and the catalog is free. I have bought accessories and supplies from them for my Grizzly 14" Ultimate and my Hitachi CBF13. They are great to work with.
Sherm
dbhost commented
