Craftsman 17539 Biscuit Joiner Review
- Created by: JSUPreston
- Published: 04-01-2013, 11:52 AM
- 1 comment
This review should also apply to the Ryobi JM82K, since other than color they are basically the same unit. I believe this is also my first review of a tool here on BT3, so please forgive me if I offend. I'm just trying to offer my honest opinion of a tool purchase.
I recently noticed that since I am a Craftsman Club member, I could get a discount on this unit. Also, by cashing in a bunch of rewards points and by ordering online, I was able to walk out the door with the unit for less than $48. Normally, the unit retails for $99.99. I got the last one at the store.
I decided to try this joiner since I had seen a lot of good user reviews on line. I have an older Craftsman joiner (17501)that isn't very good at all. Plastic fence with a lot of slop and deflection. I've ruined quite a few pieces of wood (and projects) trying to use it. I know that biscuits are not very strong structurally. I try to use them to help me line up panels and joints.
Before buying, I was at the HD and looked at the display model of the Ryobi JM82K. The locking nut for the fence was missing, so I wasn't able to really look at the fence to make sure it worked properly, but decided that since the fence was made of metal instead of plastic like my old joiner, I would probably be fine.
I got my order in less than 5 minutes from the pickup area at Sears. Less than 15 minutes later, I have it out of the box at home in my shop. Less than 17 minutes later, I've decided that I am going to return it and buy a PC 557 when finances allow.
I found in the unit I purchased that there is a lot of vertical movement in the motor housing when pushing the motor forward in the horizontal plane. I didn't measure it, but there was enough movement that it was visually noticeable. This could cause panels not to line up flat, and would cause issues similar to those I have with my old unit and its fence deflection.
The other issue I had was with the fence locking mechanism. I appears that the angle of the fence would lock in fine, but there were issues with the height. For example, when I would set the fence height to 1", the fence would move significantly when tightening down the locking nut. Usually the fence would climb as much as 1/8." I did try holding the height adjustment knob while tightening the lock, but this didn't help much.
It should be noted that I at this point I placed everything back in the box and locked it in my truck. I never plugged it in to even test the cut quality. Since Sears is just 5 minutes from work I will be returning it during lunch. I don't use a joiner much, but would rather have no joiner as opposed to one that I'm not happy with and have to fight with to adjust settings.
This joiner comes with a case, dust bag, and sample biscuits just like the Ryobi from HD. The Ryobi has a 2 year warranty, the Craftsman model only comes with a 1 year warranty. If it didn't have the problems I ran into, I would consider it a great value, especially considering all the discounts I got.Posting comments is disabled.
Categories
Article Tags
- BT3x00 (71)
- bt3000 (5)
- bt3100 (2)
- cordless (1)
- diy (2)
- dust collection (11)
- Fence Attachments (12)
- General (5)
- Hand Tool Accessories (3)
- Hand Tools (14)
- Measuring & Layout (6)
- miter fence (2)
- Mobile BT3x00 (9)
- Mobile Tools (9)
- Other Reviews (4)
- Other Tools (5)
- Power Tool Accessories (28)
- Power Tools (75)
- rails (3)
- rip fence (4)
- safety (5)
- Sharpening (4)
- t-nut (3)
- wide table kit (2)
Latest Articles
by twistsol
Summary
Channel: Tool Reviews
03-23-2022, 02:59 PM -
by LCHIENI have always had trouble mounting small hardware on small wood boxes, with the hasps and hinges always looking slightly off perfectly square - particularly a problem with flat head screws and countersunk hardware which aligns the hardware to the hole location and centers on the hole.
08-30-2021, 12:18 AM -
by twistsolSince my new shop is in the basement, dust collection is a bit more important than when I had my own building and could do as I pleased in the shop. With that in mind, I upgraded the dust collection on my table saw. I purchased the Grizzly Overarm Blade Guard to use with the saw.
07-26-2021, 03:47 PM -
by twistsol
03-19-2021, 05:57 PM -
by LCHIENHere's a tool I found useful for marking. Accutrax pencil blade marking knife.
01-14-2021, 03:25 AM -
by LCHIENHey, I'm sharing one of my favorite tools. A Veritas Saddle Square. Actually I have two in different sizes. This is the large size for marking 2x4 and 4x4 (shown on 4x4 here). One of those tools that makes woodworking a pleasure.
01-13-2021, 02:20 AM -
The SawdustZone Statistics
Topics: 61,270
Members: 20,614
Active Members: 74
Welcome to our newest member, Havoily.
What's Going On
There are currently 10920 users online. 2 members and 10918 guests.
Most users ever online was 11,606 at 02:28 AM on Today.
Footer Ad
As for alignment, if there's some leeway in their fit, the same leeway will persist for alignment. As an alternative for those conditions where a biscuit may seem appropriate, a shopmade spline from solid wood or plywood will fit better, and be more predictable.
