Harbor Freight 2-in-1 18gauge stapler/nailer contractor series
  • Harbor Freight 2-in-1 18gauge stapler/nailer contractor series
    I was wanting to get a staple gun and based on some good feedback from another poster here, I decided to give Harbor Freight a try on this model
    Harbor Freight buys their top quality tools from the same factories that supply our competitors. We cut out the middleman and pass the savings to you!
    This is the blue contractor series and not the red and silver. The gun is normally $29 and it was on sale for $15.99 so I thought I'd give it a try. Out of the box, the gun feels good in the hand. The trigger is metal as are all other major parts. The gun is slightly heavy for it's size, but not too heavy. It actually feels like decent quality. The grip is a good size and is comfortable with just the right amount of cushion. The gun is designed to shoot 3/4-2 inch 1/4" narrow crown staples or brads, both 18 gauge. Easy to load and the loading mechanism felt substantial.
    I added a 4-5 drops of oil and pressurized the gun to 60psi (range is 60-110). The first pull sent a staple in, but left it about 1/8" exposed. The next 2-3 pulls were blanks. I figured it was the oil just working in. I tried firing several more times, with the gun actually driving a staple about 1 out of ten times. The gun did not jam, but it did not feed the staples correctly. I repeated this with varying air pressure with the same result-about 1 successful staple for every 10 pulls of the trigger. Not acceptable. In addition, the gun is an air hog. My 6gal pancake compressor cycled after about the 15th shot. My craftsman 16g brad nailer will shoot about 20-25 times before the compressor cycles.
    On HF's website, there are just over 40 reviews, and an average of 4 stars, so I thought I might get lucky. I'm taking the gun back tomorrow and trying a different manufacturer. I think this one goes down as a HF miss.
    Hope that is helpful.
    • Cochese
      Cochese commented
      Originally posted by dbhost
      I don't think the blue / purple pnuematics are avaialble @ HF anymore. The red / silver models replaced them... Not sure if it is a fair trade yet...
      I have the purplish one, and never had a jam, or feed problem. Drop a few drops of oil, load the staples plug in and get to shooting staples...
      Mind you though, I would NEVER consider using this to drive nails, but when I got mine on sale, I think it was $15.00, and it drove the staples I needed driven... well what can I say, it works, I can't complain about that...
      I used mine exclusively to build my shop doors. While the hole made by the gun is larger than I like, it functions just fine as a nailer.
      cabinetman commented
      I've had very good luck with HF guns.
    • Ozzie
      Ozzie commented
      I've had very bad luck with HF nailers and staplers. I wouldn't buy one again.
    Posting comments is disabled.
Latest Articles
  • A review of the Kreg Precision Trak & Stop Kit
    by twistsol
    Summary
    03-23-2022, 02:59 PM
  • Review of VIX-type Self Centering drill bits
    by LCHIEN
    The problem comes about with small bits like 1/16 and 5/64 and 3/32"...
    08-30-2021, 12:18 AM
  • Grizzly Overarm Blade Guard review.
    by twistsol
    First impressions were that this is an extremely solid and well built unit. It's made mostly of steel and connects to a 4" DC hose. There were a number of issues getting it set up and installed, and a...
    07-26-2021, 03:47 PM
  • Kreg KMA 3220 5mm Shelf Pin Jig
    by twistsol
    I decided to look for the rock bottom cheapest 32mm drilling system available that would let let me create real 5mm holes spaced 32mm apart, that was easy to use, and didn’t require a bunch of setup time. I’m really surprised at how much I like this little Keg jig especially when you consider the price of $34.99, and it has everything included. There were a couple of jigs cheaper but you needed to buy a self-centering 5mm bit to go along with them so they would...
    03-19-2021, 05:57 PM
  • Knife marking pencil Accutrax
    by LCHIEN
    Here's mine. I have not broken it, it seems to be quite sturdy. The sharp edge lasts a long time. I'm still on the...
    01-14-2021, 03:25 AM
  • Saddle squares
    by LCHIEN
    Works really well when the board has a rounded edge or some wane where the edge is not really sharp and square but the two adjacent faces are square to...
    01-13-2021, 02:20 AM
The SawdustZone Statistics
Topics: 61,283   Posts: 558,546   Members: 20,626   Active Members: 66
Welcome to our newest member, pablosala.
What's Going On
There are currently 2957 users online. 1 members and 2956 guests.
Most users ever online was 11,606 at 02:28 AM on 03-29-2024.
