Irwin Chisels 4pk by "Marples"
- Created by: sailor55330
- Published: 02-06-2010, 08:09 PM
- 8 comments
Picked up a 4pk of basic chisels. By Irwin, labeled Marples on the package. Got them from PMenards on sale for $22. Got them home, handles are cheap plastic, blades very very dull. For $22, I'm not worried too much, but overall, very unimpressed. I will use them to split firewood I guess. I may try to sharpen then, but probably not.Posting comments is disabled.
Categories
Article Tags
- BT3x00 (71)
- bt3000 (5)
- bt3100 (2)
- cordless (1)
- diy (2)
- dust collection (11)
- Fence Attachments (12)
- General (5)
- Hand Tool Accessories (3)
- Hand Tools (14)
- Measuring & Layout (6)
- miter fence (2)
- Mobile BT3x00 (9)
- Mobile Tools (9)
- Other Reviews (4)
- Other Tools (5)
- Power Tool Accessories (28)
- Power Tools (75)
- rails (3)
- rip fence (4)
- safety (5)
- Sharpening (4)
- t-nut (3)
- wide table kit (2)
Latest Articles
by twistsol
Summary
Channel: Tool Reviews
03-23-2022, 02:59 PM -
by LCHIENI have always had trouble mounting small hardware on small wood boxes, with the hasps and hinges always looking slightly off perfectly square - particularly a problem with flat head screws and countersunk hardware which aligns the hardware to the hole location and centers on the hole.
08-30-2021, 12:18 AM -
by twistsolSince my new shop is in the basement, dust collection is a bit more important than when I had my own building and could do as I pleased in the shop. With that in mind, I upgraded the dust collection on my table saw. I purchased the Grizzly Overarm Blade Guard to use with the saw.
07-26-2021, 03:47 PM -
by twistsol
03-19-2021, 05:57 PM -
by LCHIENHere's a tool I found useful for marking. Accutrax pencil blade marking knife.
01-14-2021, 03:25 AM -
by LCHIENHey, I'm sharing one of my favorite tools. A Veritas Saddle Square. Actually I have two in different sizes. This is the large size for marking 2x4 and 4x4 (shown on 4x4 here). One of those tools that makes woodworking a pleasure.
01-13-2021, 02:20 AM -
The SawdustZone Statistics
Topics: 61,270
Members: 20,614
Active Members: 74
Welcome to our newest member, Havoily.
What's Going On
There are currently 10877 users online. 2 members and 10875 guests.
Most users ever online was 11,606 at 02:28 AM on Today.
Footer Ad
Ditto what everybody else said. I have the Sheffiled chisels and they are good, solid chisels that are used regularly, stay sharp for a long time and sharpen easily. OK balance and durable when you need to beat on them. Sad to hear they are now chinese made and a victim of mediocre quality.
Any chisel that cost under $45 per chisel "today" is not going to come honed straight out of the box. You have to flatten the backs and take the machine grind marks out.. then sharpen the bevel edge. As far as the cheap plastic.. it it high impact plastic and I have been pounding my 1/4".. 3/8".. 1/2" for 36 years with a mallet chopping dove-tail waste. You could not tell it has been pounded after all that time.
Mine are excellent chisels but.. if it is a cheaper grade steel used now you probably can't complain about that for the just over $5 apiece you paid. I would suggest flatten the back... hone the bevel and pound away.
Good luck...
