Shop Vac 801-75-11 Sawdust Collection System **** UPDATED ****
The Shop Vac Sawdust Collection System Catalog #801-75-11, is a great dust collection alternative to those that lack the space, or funding for a dedicated comparable DC unit and plumbing.
The kit comes will all the bits and pieces needed to assemble a basic, straight forward dust collection plumbing system, 36" pipe segments, 90 and 45 degree elbows, pipe couplers, directional tee fittings, friction fit blast gates, pipe hangers and hardware kit. For all but the most basic setups this is adequate. However, if your shop setup is in a garage or a basement where you have to pipe around walls and corners, there are simply too few elbows to make the turns.
I dinged them on quality because I found that the clear PVC tubing is a very loose fit into the fittings making for a very leaky vacuum system. In order to correct this I had to end wrap each piece of tubing with 1 winding of black PVC Electrical tape. This gave a good snug fit.
The fittings, and blast gates have a good tight fit to one another, and to shop vac hose ends, creating no, or at least minimal opportunity for vacuum leak.
When setting up your system, it is important to note that you may not want to use the 90 degree elbows to go up a wall going to the vac as this can cause the debris to lose velocity and drop back into the elbow. Planning and use of the 45 degree elbows can accomodate those rises needed to clear door frames and the like...
Just like with any other DC system, the fewer 90 degree bends the better.
Considering that Shop Vac has had these things on sale now for a while at $39.99, when other online vendors are getting $90.00 or so for the kit, buying two to get all the pieces and parts you need is well worth it.
To summarize, overall this is a good kit, with a slightly off size main tube. The issues with the tube are easily remedied with electrical tape. Better design and quality control from Shop Vac would have made this unnecessary. Even with its weaknesses, this is a good kit that goes a long way to getting proper dust collection and control into the hands of those of us with restricted budgets.Posting comments is disabled.
Categories
Article Tags
- BT3x00 (71)
- bt3000 (5)
- bt3100 (2)
- diy (2)
- dust collection (11)
- Fence Attachments (12)
- General (5)
- Hand Tool Accessories (3)
- Hand Tools (14)
- Measuring & Layout (6)
- miter fence (3)
- Mobile BT3x00 (9)
- Mobile Tools (9)
- Other Reviews (4)
- Other Tools (5)
- Power Tool Accessories (28)
- Power Tools (75)
- rails (3)
- rip fence (5)
- router (1)
- safety (5)
- Sharpening (4)
- t-nut (3)
- wide table kit (2)
Latest Articles
by twistsol
Summary
Channel: Tool Reviews
03-23-2022, 02:59 PM -
by LCHIENI have always had trouble mounting small hardware on small wood boxes, with the hasps and hinges always looking slightly off perfectly square - particularly a problem with flat head screws and countersunk hardware which aligns the hardware to the hole location and centers on the hole.
08-30-2021, 12:18 AM -
by twistsolSince my new shop is in the basement, dust collection is a bit more important than when I had my own building and could do as I pleased in the shop. With that in mind, I upgraded the dust collection on my table saw. I purchased the Grizzly Overarm Blade Guard to use with the saw.
07-26-2021, 03:47 PM -
by twistsol
03-19-2021, 05:57 PM -
by LCHIENHere's a tool I found useful for marking. Accutrax pencil blade marking knife.
01-14-2021, 03:25 AM -
by LCHIENHey, I'm sharing one of my favorite tools. A Veritas Saddle Square. Actually I have two in different sizes. This is the large size for marking 2x4 and 4x4 (shown on 4x4 here). One of those tools that makes woodworking a pleasure.
01-13-2021, 02:20 AM -
The SawdustZone Statistics
Topics: 61,284
Members: 20,627
Active Members: 65
Welcome to our newest member, harveywall.
What's Going On
There are currently 2565 users online. 1 members and 2564 guests.
Most users ever online was 11,606 at 02:28 AM on 03-29-2024.
Footer Ad
dbhost commented
After 10 months of ownership and usage, I am wishing I had done this differently. Simply put, I need to redo my 2.5" system. It looks like the "system" will end up being simply 2 drops, one for the workbench for sanders and such, the other for the shark guard on the BT.
My issues with the Shop Vac system are based on quality, or lack thereof. The tubing and connectors expand and contract at different rates, and of the 10 connectors used in my system, 5 of them have split in the 10 months I have had it installed. The varied expansion and contraction of the system cause countless leaks, which impact CFM and static lift at the hose end. jams with shavings are frequent events, and having to separate the pipes to clear clogs is getting to be all too frequent.
I must change my recommendation to a DO NOT RECOMMEND. When first installed it works great, but in the long haul it is a WASTE OF MONEY AND EFFORT.
