Central Machinery 98303-0VGA T Track Hold Down Clamp
Such a simple device, but with so many HF tools having such bad fit and finish, the 98303-0VGA T Track Hold Down clamps were a pleasant surprise. The stamped, and bent steel clamp arms were well dressed, and the finish is nice and solid, the rubber non mar caps are quite simple and effective, and the knob / nut is cleanly dressed with no sharp edges, and the knob feels good and solid.
While I could have (and probably should have) shop built my own solution, I needed to maximize shop time on other projects, and I HAD to have hold downs for my DP table. These solved the problem for about half of what other vendors sell similar items for. The aluminum slot adapters in my T slot were useless, but the bolt heads were just the right size. They work very well. I am happy with them...-
#1Waddles commented12-31-2008, 05:19 AMEditing a commentThe aluminum slot adapters work perfectly in my miter track (ant the heads of the bolts perfectly in my Kreg T-track). Well worth the $5.
Posting comments is disabled. -
Categories
Article Tags
- BT3x00 (71)
- bt3000 (5)
- bt3100 (2)
- diy (2)
- dust collection (11)
- Fence Attachments (12)
- General (5)
- Hand Tool Accessories (3)
- Hand Tools (14)
- Measuring & Layout (6)
- miter fence (3)
- Mobile BT3x00 (9)
- Mobile Tools (9)
- Other Reviews (4)
- Other Tools (5)
- Power Tool Accessories (28)
- Power Tools (75)
- rails (3)
- rip fence (5)
- router (1)
- safety (5)
- Sharpening (4)
- t-nut (3)
- wide table kit (2)
Latest Articles
by twistsol
Summary
Channel: Tool Reviews
03-23-2022, 02:59 PM -
by LCHIENI have always had trouble mounting small hardware on small wood boxes, with the hasps and hinges always looking slightly off perfectly square - particularly a problem with flat head screws and countersunk hardware which aligns the hardware to the hole location and centers on the hole.
08-30-2021, 12:18 AM -
by twistsolSince my new shop is in the basement, dust collection is a bit more important than when I had my own building and could do as I pleased in the shop. With that in mind, I upgraded the dust collection on my table saw. I purchased the Grizzly Overarm Blade Guard to use with the saw.
07-26-2021, 03:47 PM -
by twistsol
03-19-2021, 05:57 PM -
by LCHIENHere's a tool I found useful for marking. Accutrax pencil blade marking knife.
01-14-2021, 03:25 AM -
by LCHIENHey, I'm sharing one of my favorite tools. A Veritas Saddle Square. Actually I have two in different sizes. This is the large size for marking 2x4 and 4x4 (shown on 4x4 here). One of those tools that makes woodworking a pleasure.
01-13-2021, 02:20 AM -
The SawdustZone Statistics
Topics: 61,290
Members: 20,633
Active Members: 67
Welcome to our newest member, mohdarmanchouhan.
What's Going On
There are currently 9061 users online. 2 members and 9059 guests.
Most users ever online was 11,606 at 02:28 AM on 03-29-2024.
Footer Ad
