Jet AFS1000B air filter
The Jet AFS1000B is basically a big metal box with a squirrel-cage fan and two-stage filter system. It draws the air through the filters on one end, and blows it out the other end. It has a control panel on the box as well as a remote control. There are three speeds as well as a timer system so you can leave it running when you leave the shop, to finish cleaning up, and then shut itself off. The outside filter is a standard HVAC type, and the inside filter is a proprietary sub-micron arrangement with much more surface area.
On arrival, my first thought was to wonder how I'm going to get the thing installed on the ceiling. It is very heavy on one end, and overall it is constructed very well. This is good, but not so helpful when you have to hold it up to the ceiling. For a typical finished garage with low ceilings, you will need to hold it up to the ceiling while someone *quickly* drives screws into the brackets. Jet made no effort to ease the hassle of hanging it. The brackets have to go on the unit first, then you fasten the whole thing to the ceiling. There are also hanging mounts for cable or chain, but with our low, finished ceiling the brackets made more sense. If you have rafters or high ceilings you may want to use chain and something like carabiner clips so you can quickly snap them on. In fact with open rafters you can use a rope to hoist and suspend it while you attach the permanent mountings.
Noise level is not bad. Having a low ceiling seems to reflect the sound down much more than the demo I heard in the store, which seemed much quieter (20' ceilings). It's not bad on low, but pretty loud on high. However it's still MUCH quieter than any DC or any of the tools. It's a white noise that is not annoying at all, except that it drowns out the radio. I really should consider wearing headphones around the shop anyway, so I may move to that instead of the radio. Overall it's not objectionable and worth the health improvement.
Last night I used it while plasma cutting and welding, and it helped clean up the air quickly, as well as just providing gentle air motion to move fumes out of my face without blowing away the shielding gas. I also did a little sanding without DC and it really felt like the air was cleaned very quickly. I don't have a way to measure the results yet, a particle counter is on the way and I'll post results.
The remote control is very handy and works from almost anywhere in the shop, even from behind the unit. It has enough power to bounce off the walls and control it. There is a loud beep from the air cleaner each time it receives a signal, so you know it worked. There's also a control panel on the unit that is clear and easy to use. Overall I would say that controls are perfect. Oh, and both the remote and panel use sealed membrane switches so dust and even a liquid spill should be no problem for them.
It's a good addition to the shop and one I'd recommend for the health benefits as well as just reducing the dust annoyance.Posting comments is disabled.
Categories
Article Tags
- BT3x00 (71)
- bt3000 (5)
- bt3100 (2)
- diy (2)
- dust collection (11)
- Fence Attachments (12)
- General (5)
- Hand Tool Accessories (3)
- Hand Tools (14)
- insty (1)
- Measuring & Layout (6)
- miter fence (3)
- Mobile BT3x00 (9)
- Mobile Tools (9)
- Other Reviews (4)
- Other Tools (5)
- Power Tool Accessories (28)
- Power Tools (75)
- rails (3)
- rip fence (5)
- safety (5)
- Sharpening (4)
- t-nut (3)
- wide table kit (2)
Latest Articles
by twistsol
Summary
Channel: Tool Reviews
03-23-2022, 02:59 PM -
by LCHIENI have always had trouble mounting small hardware on small wood boxes, with the hasps and hinges always looking slightly off perfectly square - particularly a problem with flat head screws and countersunk hardware which aligns the hardware to the hole location and centers on the hole.
08-30-2021, 12:18 AM -
by twistsolSince my new shop is in the basement, dust collection is a bit more important than when I had my own building and could do as I pleased in the shop. With that in mind, I upgraded the dust collection on my table saw. I purchased the Grizzly Overarm Blade Guard to use with the saw.
07-26-2021, 03:47 PM -
by twistsol
03-19-2021, 05:57 PM -
by LCHIENHere's a tool I found useful for marking. Accutrax pencil blade marking knife.
01-14-2021, 03:25 AM -
by LCHIENHey, I'm sharing one of my favorite tools. A Veritas Saddle Square. Actually I have two in different sizes. This is the large size for marking 2x4 and 4x4 (shown on 4x4 here). One of those tools that makes woodworking a pleasure.
01-13-2021, 02:20 AM -
The SawdustZone Statistics
Topics: 61,290
Members: 20,633
Active Members: 68
Welcome to our newest member, Foster Kingston.
What's Going On
There are currently 6939 users online. 1 members and 6938 guests.
Most users ever online was 11,606 at 02:28 AM on 03-29-2024.
Footer Ad
I agree that the unit works very well. I don't have the problem described with excessive noise I can easily hear what is taking place in the shop as I normally have my scanner on. I have mine hung on 3" long chains from a finished ceiling.
It is possible to reduce transferred noise to the joists (if that's the case) by using some rubber or cloth straps.
Don't forget that Rockler has this unit on sale for $229 and Jet has a $25 rebate. I think that Amazon still has it for $209 with free shipping.
#1 observation--point the air cleaner towards your work area, not away like the instructions say. They tell you to put the intake side towards the dust generation, but that seems backwards to me. The biggest issue in our shop, which has good DC, is the lathe. There is no DC and while I hope to add some, it probably won't catch a lot. So I pointed the air cleaner towards the lathe area. The air monitor confirms this choice, showing an instant improvement in air quality in that area. Basically it's supplying the work area with filtered air. The monitor reports "good" to "very good" air.
The air filter really cleans the shop FAST. Faster than you'd think from doing the math. What happens is that the particulate count goes down very quickly, though it doesn't return to the "fully clean" range for much longer. However it goes from being in the thousands to the 150 range very fast. I believe this is an important health benefit.
