Denali 3- by 48-Inch Medium Duty Bar Clamp
Well I bought some of these through the Bargain alert of a couple of days ago and someone asked
"I wonder how much flex you would get on this 48" bar."
So I decided to write a review.
First my subjective opinion. This is a very well built clamp. It is very heavy at about 7 lbs per clamp. It is also in my opinion heavier per foot, that other similar clamps that I own. In other words the 24 clamps I have don't weigh 3.5 lbs, they way more like two. The bar seems thicker in both dimensions that the 24 inchers. I suppose it has to be, because of the extra length.
The action is very smooth, and moving the clamping head along the bar is very easy. The head locks in very solidly.
The two heads are actually tilted in towards the work by about 3 degrees when not clamped, and compared to both my Striaght edge, and my 4 foot level the bar seems very striaght.
To test the Clamping force I used a piece of 4X4 pressure treated pine about 3 feet Nine Inches long, and clamped End grain to End grain, as if I was trying to make the piece shorter.
Once clamped the Heads moved to become right angles to the bar, and if you keep clamping then they will move out of a right angle away from the work by about 2 of 3 degrees.
I was able to apply enough clamping force that even with the rubber pad on the clamp side I was able to slightly dent, or leave a round inpression on the end grain of the 4x4.
During this the bar did not flex at all that I could tell. If it did it was not measurable by me.
As a disclaimer, I have never seen a really good quailty clamp like a Jorgenson, but I would have no problems recommmending these clamps.
JohnPosting comments is disabled.
Categories
Article Tags
- BT3x00 (71)
- bt3000 (5)
- bt3100 (2)
- diy (2)
- dust collection (11)
- Fence Attachments (12)
- General (5)
- Hand Tool Accessories (3)
- Hand Tools (14)
- insty (1)
- Measuring & Layout (6)
- miter fence (3)
- Mobile BT3x00 (9)
- Mobile Tools (9)
- Other Reviews (4)
- Other Tools (5)
- Power Tool Accessories (28)
- Power Tools (75)
- rails (3)
- rip fence (5)
- safety (5)
- Sharpening (4)
- t-nut (3)
- wide table kit (2)
Latest Articles
by twistsol
Summary
Channel: Tool Reviews
03-23-2022, 02:59 PM -
by LCHIENI have always had trouble mounting small hardware on small wood boxes, with the hasps and hinges always looking slightly off perfectly square - particularly a problem with flat head screws and countersunk hardware which aligns the hardware to the hole location and centers on the hole.
08-30-2021, 12:18 AM -
by twistsolSince my new shop is in the basement, dust collection is a bit more important than when I had my own building and could do as I pleased in the shop. With that in mind, I upgraded the dust collection on my table saw. I purchased the Grizzly Overarm Blade Guard to use with the saw.
07-26-2021, 03:47 PM -
by twistsol
03-19-2021, 05:57 PM -
by LCHIENHere's a tool I found useful for marking. Accutrax pencil blade marking knife.
01-14-2021, 03:25 AM -
by LCHIENHey, I'm sharing one of my favorite tools. A Veritas Saddle Square. Actually I have two in different sizes. This is the large size for marking 2x4 and 4x4 (shown on 4x4 here). One of those tools that makes woodworking a pleasure.
01-13-2021, 02:20 AM -
The SawdustZone Statistics
Topics: 61,290
Members: 20,633
Active Members: 68
Welcome to our newest member, Foster Kingston.
What's Going On
There are currently 7069 users online. 2 members and 7067 guests.
Most users ever online was 11,606 at 02:28 AM on 03-29-2024.
Footer Ad
Aside from the color scheme, the short ones are no different than those from Harbor Freight Tools.
The long ones though, are a different story. The bar measures nearly 1" x 5/16", compared to 3/4" x 3/16" for the small ones. The handles are quite a bit beefier too, and the throat depth is an inch greater. At the $12/pr sale price these are quite a bargain.
I think I finally have "enough" clamps.
(EDIT) I'm afraid I overlooked the "rating" poll when I posted, and inadvertently gave a poor review to the original poster. Sorry.
I am a fan. I received these from the big A. My god, these are beefy units for "medium duty". For $11 per pair it was an amazing steal. Now I can finally do proper casework
As far as documentation goes?? Do you really need instructions on a bar clamp, lol.
