Harbor Freight Chisels
I picked up a 6 piece Chinese Chisel set for $8.00 at Harbor Freight expecting to find I actually had a 6 piece gasket scraper set (1/4" thru 1 1/2"), but once I cleaned them up with some wet/dry sandpaper and glass (Scarysharp trick) and gave them a little hollow grind with a cool grinder I was delighted to find they work just fine and keep an adequate edge for what I was doing (softwood shaping). I wouldn't expect them to hold up under heavy pounding and abuse, but I was trimming some round tenons on fir and they were great. If I win the Lottery I'll have a big box of Marples chisels for every task at hand, but until then these will do fine, and I won't worry too much if I drop them off my boat.
The original grind marks are VERY coarse, so I had to start with 320 to get those out. Going thru the grits, it became obvious that these were salvaged steel as there is a preceptible change in both color and hardness across the face of the bigger blades. I didn't try the full treatment, just used 320, 600, 1000 and 1500 to give them a workable edge. The grips are round softwood with a brass ring at the back to keep them from splitting should you need to beat on them a bit. The finish is inelegantly sprayed shellac, but they're workbox tools, not showpieces. Ferrules are cheap stampings but the edges on mine were deburred adequately. These tools were obviously much softer steel than my good chisels, but for something I can take outside or down to the dock I'm delighted! If you get some, do invest the time in cleaning them up and giving them a proper edge and I think you'll be as pleased and surprised as I was.-
#1Uncle Cracker commented06-17-2007, 02:14 PMEditing a commentSurprised to hear that. I have not tried any HF edged tools, as I have heard so many horror stories. I was not surprised about the salvaged steel comment, as I know that China is rehabbing their rail system, and railroad steel is abundantly recycled in their manufacturing sector.
#2wilderness1989 commented06-21-2007, 12:12 AMEditing a commentOriginally posted by Uncle Cracker
#3Halverson commented08-17-2007, 11:37 PMEditing a commentI also bought a set of those chisels and like you, I found there were a lot of burs along the edges. But I worked to get them scary sharp and now have edges that can and will shave my arm. Plus, they're not too hard to resharpen. I haven't used them on heavy dense wood - so can't comment on how long they will hold an edge in that type of wood, but for the doors around the house and the trim pieces I usually work with - they're great.
Posting comments is disabled. -
Categories
Article Tags
- BT3x00 (71)
- bt3000 (5)
- bt3100 (2)
- diy (2)
- dust collection (11)
- Fence Attachments (12)
- General (5)
- Hand Tool Accessories (3)
- Hand Tools (14)
- Measuring & Layout (6)
- miter fence (3)
- Mobile BT3x00 (9)
- Mobile Tools (9)
- Other Reviews (4)
- Other Tools (5)
- Power Tool Accessories (28)
- Power Tools (75)
- rails (3)
- rip fence (5)
- router (1)
- safety (5)
- Sharpening (4)
- t-nut (3)
- wide table kit (2)
Latest Articles
by twistsol
Summary
Channel: Tool Reviews
03-23-2022, 02:59 PM -
by LCHIENI have always had trouble mounting small hardware on small wood boxes, with the hasps and hinges always looking slightly off perfectly square - particularly a problem with flat head screws and countersunk hardware which aligns the hardware to the hole location and centers on the hole.
08-30-2021, 12:18 AM -
by twistsolSince my new shop is in the basement, dust collection is a bit more important than when I had my own building and could do as I pleased in the shop. With that in mind, I upgraded the dust collection on my table saw. I purchased the Grizzly Overarm Blade Guard to use with the saw.
07-26-2021, 03:47 PM -
by twistsol
03-19-2021, 05:57 PM -
by LCHIENHere's a tool I found useful for marking. Accutrax pencil blade marking knife.
01-14-2021, 03:25 AM -
by LCHIENHey, I'm sharing one of my favorite tools. A Veritas Saddle Square. Actually I have two in different sizes. This is the large size for marking 2x4 and 4x4 (shown on 4x4 here). One of those tools that makes woodworking a pleasure.
01-13-2021, 02:20 AM -
The SawdustZone Statistics
Topics: 61,290
Members: 20,633
Active Members: 67
Welcome to our newest member, mohdarmanchouhan.
What's Going On
There are currently 9162 users online. 1 members and 9161 guests.
Most users ever online was 11,606 at 02:28 AM on 03-29-2024.
Footer Ad
