WrkWatchr's Mobile BT3000 Cabinet
Mobile BT3000 Cabinet By Roy Shrove
I picked up this BT used out of an ad in the paper. When I got it, I had already been a BT3k'r for about 3 years. I picked up my first BT when the old Builder's Square was morphing into HQ and changing from the Ryobi line to Bosch. I had been looking into "real iron" but decided for the $114 I paid for it (when the BT was selling for around $600) that I could used it while I saved enough money for a "real" saw. Needless to say, I fell in love with the BT. Even though it was an abused floor model, all adjustments were dead-on and have stayed that way for 2+ years. Anyway, I started to collect accessories so that I could put together a wide-table version of the BT.
Fast forward almost 3 years. I had been reading with interest the great deals that everyone was getting on their BTs as Lowes was clearing them out. One Saturday I was glancing through the local want adds and spied a Ryobi table saw with accessories for $150. I just had to call. I found out the saw included the wide table kit, legs, two long miter fences, eight carbide blades as well as other miscellaneous woodworking supplies. SOLD!!!! (I also sold the accessories I had begin to purchase for my original BT making this saw virtually FREE!)
Now that I had my wide-table kit, (as well as another complete BT) the only real thing I was missing was the space to store everything in my garage. I decided to build the cabinet you see primarily as additional storage. Since I already had a dedicated router table, I didn't need the integral BT router fixture.
Building Notes:
The right side cabinet is made out of 3/4 Birch veneer plywood from HD. I rabbetted the top and bottom as well as the back for strength then glued and nailed the carcass together. The drawers were sized specifically for some of my tools and hobbies. I made the drawer sides and backs out of leftover engineered oak flooring material. The "good" veneer side was nice, but uninteresting. I liked the grain patterns on the "bad" side and decided to make it the visible side for the case front. For the cabinet under the saw (left side) I used scrap plywood to enclose the stock base and then used the same Birch ply for the doors mounted with piano hinges. The only modifications I did was to replace several of the standard 1/2" carriage bolts with 1" ones to help hold the plywood. . I retained the stock Ryobi outfeed table and used the plastic clips to mount the long miter fence on the front kick plate. The base is built on standard 2x4s with the cabinets attached with 3" deck screws. All plywood was sanded to 220 grit and finished with gloss water-based poly. The clamp rack is a 2x4 mounted between the legs. The casters are 3" HD specials with the front being locking casters. The whole unit is heavy, but mobile. Before anyone asks - the blade guard and splitter were not with the BT when I bought it. All in all, this approach takes advantage of otherwise unused space and generates a tremendous amount of storage. Hmmm...now what to do with my other BT?????
Roy
aka WrkWatchr
rshrove@satx.rr.com
Original PDF Document:
rssawcab.pdf
Posting comments is disabled.
Categories
Article Tags
- BT3x00 (71)
- bt3000 (5)
- bt3100 (2)
- cordless (1)
- diy (2)
- dust collection (11)
- Fence Attachments (12)
- General (5)
- Hand Tool Accessories (3)
- Hand Tools (14)
- Measuring & Layout (6)
- miter fence (2)
- Mobile BT3x00 (9)
- Mobile Tools (9)
- Other Reviews (4)
- Other Tools (5)
- Power Tool Accessories (28)
- Power Tools (75)
- rails (3)
- rip fence (4)
- safety (5)
- Sharpening (4)
- t-nut (3)
- wide table kit (2)
Latest Articles
by WrkWatchrMobile BT3000 Cabinet By Roy Shrove I picked up this BT used out of an ad in the paper. When I got it, I had already been a BT3k'r for about 3 years. I picked up my first BT when the old Builder's Square was morphing into HQ and changing from the Ryobi line to Bosch. I had been looking into "real iron" but decided for the $114 I paid for it (when the BT was selling for around $600) that I could used it while I saved enough money for a "real" saw. Needless to say, I fell in love with the BT. Even though it was an abused floor model, all adjustments were dead-on and have stayed that way for 2+ years. Anyway, I started to collect accessories so that I could put together a wide-table version of the BT. ...
Channel: Mobile Shops & Bases
04-29-2015, 08:17 AM -
by staffOriginally Posted by Jim Dwight in the category Mobile BT3000s
Spruce and Sandeply – Another base option By Jim Dwight (aka JimD)
The thought behind this base was to create something a bit smaller where the basic structure could be cut from one sheet of 3⁄4 plywood. ...-
04-29-2015, 07:50 AM -
by staffOriginally Posted by Pat Greco in the category Mobile BT3000s Although this article does not contain any supporting text or instructions, it's photos give some great direction for adding multiple miter slots and a shop made outfeed table to the BT3000. ...
04-29-2015, 07:14 AM -
by Sam ConderMaroon & Maple – A Mobile BT3 Cabinet By Sam Conder Ever since my first BT3000, I have wanted a large mobile cabinet for it and an accompanying wide table kit. It took me almost seven years, and an upgrade to my BT3100, but I finally got around to constructing my cabinet. This document gives the reader some construction notes to go on, as well as some photos. ...
04-29-2015, 07:06 AM -
by staffOriginally Posted by Jeff Browning in the category Mobile BT3000s
Jeff Browning built this excellent BT3000 rolling cabinet based on the "Little Shop That Could" article in Popular Woodworking. Jeff has added miter slots, a great router fence, a high auxillery fence, and featherboards. Included in this file are several pictures of his design as well as some superb measured drawings.
browning.pdf ...-
04-29-2015, 06:48 AM -
by staffOriginally Posted by Ray Girling in the category Mobile BT3000s
Design Considerations for a Wide-Rail BT3K Mobile Cabinet
Having built my own BT3K wide-rail mobile cabinet, I thought that it might be useful to those who are still at the design stage, to those just thinking about it, or to those just interested in the concept, to read about the process I followed and what core design issues were involved. This may not result in a definitive design for you, but may, at least, focus on the critical elements of the project. I have included drawings and photographs to assist, not all to the same scale, or even to scale at all. ...-
04-29-2015, 06:19 AM -
The SawdustZone Statistics
Topics: 61,270
Members: 20,614
Active Members: 74
Welcome to our newest member, Havoily.
What's Going On
There are currently 10708 users online. 3 members and 10705 guests.
Most users ever online was 11,606 at 02:28 AM on Today.
Footer Ad
