BT3000 To 3100 Shim Upgrade
  • BT3000 To 3100 Shim Upgrade
    Upgrading the shims avoids the issue of the BT3000 shims dropping out and causing the blade-raising mechanism to bind.
    Before you begin:
    Call Ryobi technical support at 1-800-525-2579 with the serial number from your saw to
    verify that your saw is eligible for the upgrade. Some earlier BT3000s are not.
    ‘Right’ and ‘Left’ designations assume you are starting by looking at the front of the saw.
    These instructions assume a stock saw with no modifications to the blade guard assembly
    or saw body.
    Parts you will need for the conversion:
    2 each 0181010314 spring shims BT3100 part $0.43 ea
    1 each 0181010110 guide holder BT3100 part $15.07
    When you order these parts to save on shipping costs, it is recommended that you also
    order the following parts. Inspect the flat shims and belts and replace if necessary while you have
    the saw torn down. It is a good idea to have the belts on hand as spares.
    2 each 969600001 flat shim BT3000 & BT3100 part $0.45 ea
    2 each 662329001 belt BT3000 & BT3100 $13.49 ea
    You can order from www.ordertree.com, www.bilious.com, www.dixiesales.com
    Tools needed:
    Phillips screwdriver
    2 Quick Clamps (suggested)
    BT3000 Wrenches
    Socket Wrench
    Rubber Mallet
    Pointed Awl (suggested)
    Other suggested supplies:
    A small amount of grease
    #10-24 round or button-head machine screws 1 ½” long
    Dry lubricant – NOT Silcone-based!
    Anti-seize lubricant
    Upgrade Procedure:
    UNPLUG THE SAW!
    Remove the accessory table, SMT and rip fence. Remove the rails or slide them all the
    way to the right. Raise the blade to full height. Remove the throat plate. Bag and label
    the screws.
    Remove the blade guard/riving knife assembly. Remove the blade. Bag the
    arbor nut, washers and arbor shims.
    Remove the left access panel from the saw. Bag
    and label the screws.
    Remove the blade shroud cover. Bag and label the screws.
    There are 4 screws in each corner of the blade guide holder and 2 smaller screws on either side of the arbor. Remove the two screws around the arbor. If the 4 screws in the blade guide holder will not turn, use the rubber mallet and rap on the end of the handle of the
    screwdriver while backing the screws out. Using a power/drill driver to remove these screws is NOT recommended – the screws are easily stripped. Once all 6 screws are removed, bag and label the screws. Us the rubber mallet to rap gently on the end of the saw arbor while wiggling the blade guide holder off. Stop and pick up the flat shims that
    have fallen on the floor.
    Finish removing the blade guide holder. Remove the nuts and
    shims from the bolts that hold the riving knife/blade guard. Push on the ends of the bolts to free the retaining clip from the guide holder and remove the bolts While the saw is
    disassembled, it is a good idea to give the motor assembly a thorough cleaning.
    Reassembly:
    Inspect the belts and flat shims. Replace as necessary. Install the bolts and retaining clip for the riving knife in the new guide holder. Install the shims and nuts onto the bolts.
    Tighten the nuts at least finger-tight to ensure they stay in place. Put some dri-lube into the arbor hole in the guide holder. Put a small dab of grease onto the guide holder in each of the shim locations and add the new spring shims. This picture shows the positioning
    of the shims:
    Put a small dab of grease on the flat shims and install them onto the saw motor. The grease will help hold the shims in place. Install the new guide holder/shims onto the saw. Use the awl in the screw holes to get the flat shims, guide holder, brackets, etc lined up. Depending on tolerances, the guide holder may bind on the arbor during installation. There are two methods to get it fully seated on the saw.
    Method 1: Use the quick clamps and alternately tightening each one to seat the guide
    holder.
    Method 2: I found this more effective, easier is to use and gave me more control. Use the 4 1 ½” screws to seat the guide holder. Tighten each screw alternately until the guide holder is seated far enough on the arbor to use the stock screws. A power drill/driver is NOT recommended. Since these screws are longer than the stock screws, tightening them too much will cause them to bottom out and bind. Only tighten them enough to seatthe guide holder far enough onto the arbor so that the stock screws can be used. Remove the longer screws. Apply some anti-seize to the stock screws and reinstall the stockscrews. Finish the guide holder installation.
    Reinstall the two smaller screws around the saw arbor. Again, use the awl to get everything lined up. Use more dri-lube to lubricate the travel for the new shims. Test the blade raising/lowering mechanism to ensure nothing is binding.
    Reassemble the saw and double-check the alignment.
    • spelljammer
      spelljammer commented
      Shims
      Wow! You folks are loaded with info. It seems that the shims are one of the biggest complaints with the saw. I want to do what I can to make mine the best it can be. Thanks for the great post. -Mark
    • Hutch
      Hutch commented
      Gardner (garderinc.com) had all of the parts on 1/5/2016 (1-800-848-8946). I found it best to call. The guy I talked to was both knowledgeable and helpful. Shipping was reasonable and prompt. From talking to him, they carry these parts and most other parts for BT3000/3100 regularly. I also ordered a new switch. I was even able to get a 4960029 U-bracket extension kit for Ryobi TSS200 miter saw. It is probably the last one in the world as it was discontinued almost a decade ago.
    • wbrewer
      wbrewer commented
      Where is the picture that shows the positioning of the shims?
    Posting comments is disabled.
Latest Articles
  • Screw friction products EZ-Grip and Screw Grab?
    by LCHIEN
    I was reading an article about fasteners the other day.
    They mentioned a couple of products I had not heard of before:
    EZ-grip and Screw Grab
    Apparently if you have a screw that you have a hard time engaging like a worn Phillips, a drop of these products will increase the friction between the screw and the driver 8X it is claimed so that you can back out the screw.
    You can find them both at Amazon.
    Not cheap 5 oz of EZ-GRIP is $20; 1/2 oz of Screw...
    04-07-2022, 10:58 AM
  • A Cure for the Shim Problem on the Ryobi BT3000
    by twistsol
    Originally written by Norm Havens and re-posted here.
    Editor's Note: The site where this article appeared originally is now gone. I had this article saved as a .pdf file from years ago and resurrected the article from that.
    December 3, 2000 I must be totally star-crossed this week . . .
    "Trouble comes in threes," didn't someone say? This week I've already dinged the blades of my new planer, nearly dropped my router from the accessory table, and now...
    08-29-2018, 11:21 AM
  • Ryobi BT3000 and BT3100 Manuals
    by twistsol
    The manual from the old site is out of date and many of the links in it were broken. The downloadable .PDF manuals are attached below.
    11-21-2017, 10:23 AM
  • Lonnie's No Measure Alignment procedure
    by Lonnie in Orlando
    Hi Guys - I haven't been on the forum much lately ... I bought a '55 MGTF-1500 that is taking up space, time, and money that is(was) used by my woodworking shop. The car has a wood frame beneith the body panels, so I guess it counts as woodworking. Thanks for resurrecting my No-Measure alignment thread. I see that it has lost some of the attachments. So I reposted it below. Note - there are a lot of good ways to adjust a BT3K or any other table saw. This is the one that I found is best for...
    04-29-2015, 09:49 AM
  • BT3K Shim Replacement
    by Black wallnut
    Since it seems time for my semi-annual maintenance and due to several posts asking how to lately I deciced to take pictures during mine. Keep in mind this is specifically for the BT3000 only.
    Step 1: double un-plug saw at outlet and onboard outlet. Remove throat plate, Sharkguard, Big dog clamp, and splitter (or the stock POS []). Remove blade and spacers.
    Step 2: remove left side cover and dust shroud.
    Step 3: remove the four...
    04-29-2015, 09:41 AM
    by crokett
    Before you begin:
    04-29-2015, 09:33 AM
The SawdustZone Statistics
Topics: 61,283   Posts: 558,546   Members: 20,626   Active Members: 66
Welcome to our newest member, pablosala.
What's Going On
There are currently 2581 users online. 3 members and 2578 guests.
Most users ever online was 11,606 at 02:28 AM on 03-29-2024.
