BT3X00 Shim Maintenance Aid
My 7 year old BT3000 finally refused to raise or lower the blade and I had to do some shim maintenance.
So, I came back to bt3central to review recent articles on shim maintenance.
David Green's article on using the BT3100 parts is part of my long term plan http://www.bt3central.com/showthread.php?t=33948 (parts are on order).
Mark Stripes article on shim maintenance was very helpful. http://www.bt3central.com/showthread.php?t=27266 I really liked his idea to use 1 1/2" 10-24 screws to help get the guide holder into place.
While looking for longer 10-24 screws I found a 3" piece of 10-24 all-thread rod and thought that would work.
Here is a picture of the rods holding the flat shims in place.
Note: insert shims then screw in the rods.
As you can see the rods give you four alignment posts to help ease the guide holder into place.
This is the only deviation from Mark's very detailed procedure.
Thanks to Dave and Mark for their help.Posting comments is disabled.
Categories
Article Tags
- BT3x00 (71)
- bt3000 (5)
- bt3100 (2)
- diy (2)
- dust collection (11)
- Fence Attachments (12)
- General (5)
- Hand Tool Accessories (3)
- Hand Tools (14)
- Measuring & Layout (6)
- miter fence (3)
- Mobile BT3x00 (9)
- Mobile Tools (9)
- Other Reviews (4)
- Other Tools (5)
- Power Tool Accessories (28)
- Power Tools (75)
- rails (3)
- rip fence (5)
- router (1)
- safety (5)
- Sharpening (4)
- t-nut (3)
- wide table kit (2)
Latest Articles
by LCHIENI was reading an article about fasteners the other day.
They mentioned a couple of products I had not heard of before:
EZ-grip and Screw Grab
Apparently if you have a screw that you have a hard time engaging like a worn Phillips, a drop of these products will increase the friction between the screw and the driver 8X it is claimed so that you can back out the screw.
You can find them both at Amazon.
Not cheap 5 oz of EZ-GRIP is $20; 1/2 oz of Screw...-
Channel: Maintenance & Repairs
04-07-2022, 10:58 AM -
by twistsolOriginally written by Norm Havens and re-posted here.
Editor's Note: The site where this article appeared originally is now gone. I had this article saved as a .pdf file from years ago and resurrected the article from that.
December 3, 2000 I must be totally star-crossed this week . . .
"Trouble comes in threes," didn't someone say? This week I've already dinged the blades of my new planer, nearly dropped my router from the accessory table, and now...-
08-29-2018, 11:21 AM -
by twistsolThe manual from the old site is out of date and many of the links in it were broken. The downloadable .PDF manuals are attached below.
11-21-2017, 10:23 AM -
Hi Guys - I haven't been on the forum much lately ... I bought a '55 MGTF-1500 that is taking up space, time, and money that is(was) used by my woodworking shop. The car has a wood frame beneith the body panels, so I guess it counts as woodworking. Thanks for resurrecting my No-Measure alignment thread. I see that it has lost some of the attachments. So I reposted it below. Note - there are a lot of good ways to adjust a BT3K or any other table saw. This is the one that I found is best for...
04-29-2015, 09:49 AM -
Since it seems time for my semi-annual maintenance and due to several posts asking how to lately I deciced to take pictures during mine. Keep in mind this is specifically for the BT3000 only.
Step 1: double un-plug saw at outlet and onboard outlet. Remove throat plate, Sharkguard, Big dog clamp, and splitter (or the stock POS []). Remove blade and spacers.
Step 2: remove left side cover and dust shroud.
Step 3: remove the four...-
04-29-2015, 09:41 AM -
by crokettUpgrading the shims avoids the issue of the BT3000 shims dropping out and causing the blade-raising mechanism to bind.
Before you begin:
Call Ryobi technical support at 1-800-525-2579 with the serial number from your saw to
verify that your saw is eligible for the upgrade. Some earlier BT3000s are not.
‘Right’ and ‘Left’ designations assume you are starting by looking at the front of the saw....
These instructions assume a stock-
04-29-2015, 09:33 AM -
The SawdustZone Statistics
Topics: 61,286
Members: 20,628
Active Members: 64
Welcome to our newest member, buildergenius.
What's Going On
There are currently 5767 users online. 2 members and 5765 guests.
Most users ever online was 11,606 at 02:28 AM on 03-29-2024.
Footer Ad
