A DWG Drawing Of The BT3000
Originally Posted by Chris Hogan in the category General BT3000 Information
This file is useful when designing your own cabinet to house the BT3000. It is a basic 3D drawing of the BT3000 with extension rails. This file is a 3-D AutoCAD 14 file.
NOTE: Contrary to the instructions below, this file is not a PDF and therefore DOES NOT require Adobe Acrobat Reader. Simply click the download button and the DWG will be downloaded.
bt3000.dwgPosting comments is disabled.
Categories
Article Tags
- BT3x00 (71)
- bt3000 (5)
- bt3100 (2)
- diy (2)
- dust collection (11)
- Fence Attachments (12)
- General (5)
- Hand Tool Accessories (3)
- Hand Tools (14)
- Measuring & Layout (6)
- miter fence (3)
- Mobile BT3x00 (9)
- Mobile Tools (9)
- Other Reviews (4)
- Other Tools (5)
- Power Tool Accessories (28)
- Power Tools (75)
- rails (3)
- remote control (1)
- rip fence (5)
- safety (5)
- Sharpening (4)
- t-nut (3)
- wide table kit (2)
Latest Articles
by LCHIENI was reading an article about fasteners the other day.
They mentioned a couple of products I had not heard of before:
EZ-grip and Screw Grab
Apparently if you have a screw that you have a hard time engaging like a worn Phillips, a drop of these products will increase the friction between the screw and the driver 8X it is claimed so that you can back out the screw.
You can find them both at Amazon.
Not cheap 5 oz of EZ-GRIP is $20; 1/2 oz of Screw...-
Channel: Maintenance & Repairs
04-07-2022, 10:58 AM -
by twistsolOriginally written by Norm Havens and re-posted here.
Editor's Note: The site where this article appeared originally is now gone. I had this article saved as a .pdf file from years ago and resurrected the article from that.
December 3, 2000 I must be totally star-crossed this week . . .
"Trouble comes in threes," didn't someone say? This week I've already dinged the blades of my new planer, nearly dropped my router from the accessory table, and now...-
08-29-2018, 11:21 AM -
by twistsolThe manual from the old site is out of date and many of the links in it were broken. The downloadable .PDF manuals are attached below.
11-21-2017, 10:23 AM -
Hi Guys - I haven't been on the forum much lately ... I bought a '55 MGTF-1500 that is taking up space, time, and money that is(was) used by my woodworking shop. The car has a wood frame beneith the body panels, so I guess it counts as woodworking. Thanks for resurrecting my No-Measure alignment thread. I see that it has lost some of the attachments. So I reposted it below. Note - there are a lot of good ways to adjust a BT3K or any other table saw. This is the one that I found is best for...
04-29-2015, 09:49 AM -
Since it seems time for my semi-annual maintenance and due to several posts asking how to lately I deciced to take pictures during mine. Keep in mind this is specifically for the BT3000 only.
Step 1: double un-plug saw at outlet and onboard outlet. Remove throat plate, Sharkguard, Big dog clamp, and splitter (or the stock POS []). Remove blade and spacers.
Step 2: remove left side cover and dust shroud.
Step 3: remove the four...-
04-29-2015, 09:41 AM -
by crokettUpgrading the shims avoids the issue of the BT3000 shims dropping out and causing the blade-raising mechanism to bind.
Before you begin:
Call Ryobi technical support at 1-800-525-2579 with the serial number from your saw to
verify that your saw is eligible for the upgrade. Some earlier BT3000s are not.
‘Right’ and ‘Left’ designations assume you are starting by looking at the front of the saw....
These instructions assume a stock-
04-29-2015, 09:33 AM -
The SawdustZone Statistics
Topics: 61,284
Members: 20,628
Active Members: 63
Welcome to our newest member, harveywall.
What's Going On
There are currently 3000 users online. 1 members and 2999 guests.
Most users ever online was 11,606 at 02:28 AM on 03-29-2024.
Footer Ad
