BT3000 Quick Fold Table and Manual
I have attached the manual for those who requested it.
I found this a useful accessory. Its a fairly heavy table about the width of the BT3000 and maybe just a bit deeper than the top of the BT3.
The front attaches to the rear rail at two points of the BT3 and has a slightly beveled front to that the workpeices coming off the saw don't catch. There's a hinge right behind the rear rail which fastens to the bottom of the rear rail via T-slot using T-nuts and bolts (the hinge is articulated so that the table is at the height of the saw table). WHen open there's about a 4" or so gap between the back of the saw table and the front of the outfeed table.
The rear of the outfeed table is supposrted by a single leg which is adjustable height and it folds up so the table lies almost flat against the back fo the saw when not used. The adjustable height makes it so the workpieces coming off the saw can lie relatively flat on the outfeed while the workpiece is still flat on the saw table.
I like this table and always have it open. I did have to make one modification.
I prefer to have the table positioned so that the left and right sides match up with the normal ends of the rail and with my aux table on the right and the SMT on the left and some movement for each of them, as I think most people do.
When positioned squarely behind the saw rip cuts feed out nicely and so do any panels/sheet goods with 2-3 feet on either side of the blade.
The problem is that the left hinge of the table ends coming up behind the SMT and preventing the SMT from traveling all the way back as you would normally need. So you'd have to remove the QF table so make miter/SMT cuts, folded or not.
My solution was to move the left hinge a bit to the right, so its behind the main table. THis involves drilling and countersinking two holes for that hinge in the top of the QF table to recess the bolts holding the hinge. The rear rail is slotted the full width so there's no adjustment needed there.
Anyway the new position allows full use of the saw. The SMT can only go so far back with the QF table unfolded, but the face of the miter fence goes past the front of the blade so most all miter cuts can be made. If you need the SMT to go further back (e.g. you moved the miter fence to the front of the SMT or have some angled cut) then you can fold the QF table down and the SMT will have full travel.
The other drawback is that the hinges being closer together gives the table a little less solid feeling when folding compared to the hinges being set wider apart. But, there's no long term issue with this, I have been using this for 10+ years.Posting comments is disabled.
Categories
Article Tags
- bt3 (1)
- BT3x00 (71)
- bt3000 (5)
- bt3100 (2)
- diy (2)
- dust collection (11)
- Fence Attachments (12)
- General (5)
- Hand Tool Accessories (3)
- Hand Tools (14)
- Measuring & Layout (6)
- miter fence (3)
- Mobile BT3x00 (9)
- Mobile Tools (9)
- Other Reviews (4)
- Other Tools (5)
- Power Tool Accessories (28)
- Power Tools (75)
- rails (3)
- rip fence (5)
- safety (5)
- Sharpening (4)
- t-nut (3)
- wide table kit (2)
Latest Articles
by LCHIENSmall T-nut for the left side of BT3 rip fence or front of miter fence (Article Version)
11-30-2023, 04:00 PM
Item 1LAJ3 Mfr. Model 1LAJ3 (WW Graingers)...-
Channel: Jigs & Fixtures
12-07-2023, 12:19 AM -
by LCHIENAfter a bit more thinking, some universal T-bolts for the rip miter fence make more sense than fixture blocks.
So I took some 1/8th flat Aluminum 1.00 inches wide and cut 1-1/8" long to make a 1" x 1-1/8" rectangular plates; I used a short rip fence Block to space the length but not cause a kickback with the...-
07-09-2023, 02:37 PM -
by LCHIEN
Make the base from 1/8” aluminum bar, you can get 1.5”, 2”, and 3” at Lowes...-
05-24-2023, 09:55 PM -
by twistsolRipping thin strips can be accomplished in a number of ways, but this jig is the best I've found so far.
- There is no need to move the fence so every strip comes out exactly the same.
- It is incredibly easy to build
- It keeps your hands well away from the blade the whole time
- It keeps control of the strip you are ripping all the way through the cut and past the blade
- It doesn't interfere with the blade guard.
- You can cut strips from any length of stock
04-16-2023, 10:42 AM -
by LCHIENBT3000 tall rip fence
09-12-2021, 07:58 PM
Anyway the BT3000 tall fence is generally held on by the T-slots in the side of the rip fence. This is...-
10-20-2021, 03:27 AM -
by LCHIEN
I am finally going to use my BT3000 extension rails.
My objective is to have some easily attachable rail extensions rather than a full time wide BT3000 using two full rails taking up a lot of space and requiring table support under the right side as many do.
I just want some wider support but not to do full 4x8 sheets of ply... if I need that, I'll break the sheet down on some sawhorses with a circ saw and some guides.
I think I am going to cut my extension...-
08-14-2021, 11:32 AM -
The SawdustZone Statistics
Topics: 61,286
Members: 20,629
Active Members: 64
Welcome to our newest member, buildergenius.
What's Going On
There are currently 7085 users online. 3 members and 7082 guests.
Most users ever online was 11,606 at 02:28 AM on 03-29-2024.
Footer Ad
I am in the process of drawing up plans (thinking stage at this point) for an extension table on the left side of my BT3.
I had in mind 2x4 construction with one inch dowels, about three feet long and 18 inches wide.
I would appreciate and comments, plans or suggestions on this project.
rabmaxx
Rabmaxx
