Turning off BT3*00 from left side
After searching this site, and not being able to find an easy way to turn off the BT3*00 from the left side, I decided to post the very easy, very inexpensive, and quick solution I designed for mine. It is made from ¾” PVC pipe, elbows, a tee, and 2 short pieces of ¾” hardwood dowel. I did not glue the parts together, but they have a tight fit. If you prefer to use glue, please do, but make certain it will work (without modification), by dry fitting the assembly, and trying it before gluing.
When making it, I was concerned that the weight might be enough to trip the switch. It did not do that, but if the assembly is allowed to drop, after turning the saw on, the weight will be enough to trip the switch (off). Therefore I gently lower the assembly onto the switch plate after turning the saw on. I also made contact with the switch plate slightly on the upper half of the plate because making contact on the lower half would allow more leverage for the weight of the assembly to trip the switch. It would also be easy enough to add a compression spring to the under side of the switch plate, resulting in more pressure being needed in order to trip the switch. If you prefer to go that route, that’s entirely up to you. In the following pictures, you will notice that I used tees instead of elbows. That’s only because that’s what I had available in my leftover parts from another job. The tees will eventually be replaced with elbows, except for the one holding the short piece of PVC which makes contact with the switch plate. Following is a list of pieces, beginning with the top left, and ending with the top right (dimensions are not critical):
¾” PVC 90 degree elbow (shown as tee)
8 1/4” piece of ¾” PVC pipe
20 ½” piece of ¾” PVC pipe
5” piece of ¾” PVC pipe
¾” PVC tee (with 4” piece of ¾” PVC pipe to trip the switch)
2 ½” piece of ¾” PVC pipe
A short piece of ¾” hardwood dowel is attached with screws to the side plates of the saw for attaching the assembly. Don’t forget to drill pilot holes for the screws to eliminate splitting the dowel.
Now if you are in a position where you need to turn the saw off, but it’s difficult to reach the switch during a sawing operation, you can easily turn the saw off from the left side.
It has been suggested by another member, "bethere", that using tees instead of elbows on the bottom of the assembly would allow an extension to be inserted (in the case of cutting sheet goods, etc.)
[ATTACH]21671[/ATTACH]
[ATTACH]21672[/ATTACH]
[ATTACH]21673[/ATTACH]Posting comments is disabled.
Categories
Article Tags
- BT3x00 (71)
- bt3000 (5)
- bt3100 (2)
- diy (2)
- dust collection (11)
- Fence Attachments (12)
- General (5)
- Hand Tool Accessories (3)
- Hand Tools (14)
- Measuring & Layout (6)
- miter fence (3)
- Mobile BT3x00 (9)
- Mobile Tools (9)
- Other Reviews (4)
- Other Tools (5)
- Power Tool Accessories (28)
- Power Tools (75)
- rails (3)
- rip fence (5)
- router (1)
- safety (5)
- Sharpening (4)
- t-nut (3)
- wide table kit (2)
Latest Articles
by LCHIENSmall T-nut for the left side of BT3 rip fence or front of miter fence (Article Version)
11-30-2023, 04:00 PM
Item 1LAJ3 Mfr. Model 1LAJ3 (WW Graingers)...-
Channel: Jigs & Fixtures
12-07-2023, 12:19 AM -
by LCHIENAfter a bit more thinking, some universal T-bolts for the rip miter fence make more sense than fixture blocks.
So I took some 1/8th flat Aluminum 1.00 inches wide and cut 1-1/8" long to make a 1" x 1-1/8" rectangular plates; I used a short rip fence Block to space the length but not cause a kickback with the...-
07-09-2023, 02:37 PM -
by LCHIEN
Make the base from 1/8” aluminum bar, you can get 1.5”, 2”, and 3” at Lowes...-
05-24-2023, 09:55 PM -
by twistsolRipping thin strips can be accomplished in a number of ways, but this jig is the best I've found so far.
- There is no need to move the fence so every strip comes out exactly the same.
- It is incredibly easy to build
- It keeps your hands well away from the blade the whole time
- It keeps control of the strip you are ripping all the way through the cut and past the blade
- It doesn't interfere with the blade guard.
- You can cut strips from any length of stock
04-16-2023, 10:42 AM -
by LCHIENBT3000 tall rip fence
09-12-2021, 07:58 PM
Anyway the BT3000 tall fence is generally held on by the T-slots in the side of the rip fence. This is...-
10-20-2021, 03:27 AM -
by LCHIEN
I am finally going to use my BT3000 extension rails.
My objective is to have some easily attachable rail extensions rather than a full time wide BT3000 using two full rails taking up a lot of space and requiring table support under the right side as many do.
I just want some wider support but not to do full 4x8 sheets of ply... if I need that, I'll break the sheet down on some sawhorses with a circ saw and some guides.
I think I am going to cut my extension...-
08-14-2021, 11:32 AM -
The SawdustZone Statistics
Topics: 61,286
Members: 20,628
Active Members: 64
Welcome to our newest member, buildergenius.
What's Going On
There are currently 6677 users online. 3 members and 6674 guests.
Most users ever online was 11,606 at 02:28 AM on 03-29-2024.
Footer Ad
