Zero Clearance Throat Plates with Levelers
Custom Zero-Clearance Throat Plates With Levelers
It occurred to me almost instantly to tap out the 4 holes underneath the TP to a 10-24 thread. I had kind of cussed under my breath at the Ryobi factory for not tapping this there and adding the screws to my parts package. I also wondered why I hadn’t seen this adjustment in the manual. I guess that was not the their intended purpose. Screw in 4 screws. I use stainless steel. Then you also drill your Tp’s for these holes. 3/16”is the drill size that I use. This can vary up or down some. Then using the 3 OEM screws, attach the plate and adjust it flush with the 4 screws. Even if you have countersunk your other plates in the 4-hole area, you can drill out the other three and still adjust it flush. If you have used thicker plates though, you may have a problem. Just cut some thinner.
I like to use 1⁄4” Lexan or Plexiglas. It mills easy, it’s strong, it’s thin enough, it’s readily available, and it’s see through. What more could you ask for.
Another tip is when I make the plunge cut for the ZCTP’s, I screw the new plate on top of the OEM plate using the 3 holes. This way you don’t have to worry about breaking belts.
Lee Styron
Leesty@gulftel.com
Original PDF Document:
Lszctp.pdfPosting comments is disabled.
Categories
Article Tags
- BT3x00 (71)
- bt3000 (5)
- bt3100 (2)
- diy (2)
- dust collection (11)
- Fence Attachments (12)
- General (5)
- Hand Tool Accessories (3)
- Hand Tools (14)
- Measuring & Layout (6)
- miter fence (3)
- Mobile BT3x00 (9)
- Mobile Tools (9)
- Other Reviews (4)
- Other Tools (5)
- Power Tool Accessories (28)
- Power Tools (75)
- rails (3)
- rip fence (5)
- router (1)
- safety (5)
- Sharpening (4)
- t-nut (3)
- wide table kit (2)
Latest Articles
by LCHIENSmall T-nut for the left side of BT3 rip fence or front of miter fence (Article Version)
11-30-2023, 04:00 PM
Item 1LAJ3 Mfr. Model 1LAJ3 (WW Graingers)...-
Channel: Jigs & Fixtures
12-07-2023, 12:19 AM -
by LCHIENAfter a bit more thinking, some universal T-bolts for the rip miter fence make more sense than fixture blocks.
So I took some 1/8th flat Aluminum 1.00 inches wide and cut 1-1/8" long to make a 1" x 1-1/8" rectangular plates; I used a short rip fence Block to space the length but not cause a kickback with the...-
07-09-2023, 02:37 PM -
by LCHIEN
Make the base from 1/8” aluminum bar, you can get 1.5”, 2”, and 3” at Lowes...-
05-24-2023, 09:55 PM -
by twistsolRipping thin strips can be accomplished in a number of ways, but this jig is the best I've found so far.
- There is no need to move the fence so every strip comes out exactly the same.
- It is incredibly easy to build
- It keeps your hands well away from the blade the whole time
- It keeps control of the strip you are ripping all the way through the cut and past the blade
- It doesn't interfere with the blade guard.
- You can cut strips from any length of stock
04-16-2023, 10:42 AM -
by LCHIENBT3000 tall rip fence
09-12-2021, 07:58 PM
Anyway the BT3000 tall fence is generally held on by the T-slots in the side of the rip fence. This is...-
10-20-2021, 03:27 AM -
by LCHIEN
I am finally going to use my BT3000 extension rails.
My objective is to have some easily attachable rail extensions rather than a full time wide BT3000 using two full rails taking up a lot of space and requiring table support under the right side as many do.
I just want some wider support but not to do full 4x8 sheets of ply... if I need that, I'll break the sheet down on some sawhorses with a circ saw and some guides.
I think I am going to cut my extension...-
08-14-2021, 11:32 AM -
The SawdustZone Statistics
Topics: 61,284
Members: 20,628
Active Members: 63
Welcome to our newest member, harveywall.
What's Going On
There are currently 2407 users online. 1 members and 2406 guests.
Most users ever online was 11,606 at 02:28 AM on 03-29-2024.
Footer Ad
