BT3000 Safer Power Switch Modification
BT3000 Safer Power Switch Modification by Jim Frye
This add on to the BT3000 came about from a question on the tool forum concerning problems turning the saw off in an emergency situation. I have “missed” the switch cover many times because I was concentrating on the spinning saw blade, the work piece, the cut off, and my left hand. The stock BT3K switch cover is only 2.25 square inches in area and positioned where it is, can be a difficult target to hit the first time. There is a large switch on the market that measures something like 12” square, but my tool budget is a bit pinched. I came up with what amounts to an extension for the stock switch cover. I used a 6” wide by 10” long piece of thin rigid plastic. This produces a larger target of 60 square inches. This could be 1/8” plexiglas or thinner also. It doesn’t have to be very strong, just stiff enough to cause the switch to turn off when struck. It also can’t be very heavy or it will turn the saw off by it’s own weight. This cover extension is mounted on the existing cover with double sided carpet tape. This tape has fabric in it and is very strong. The extension could also be mounted with small screws and nuts if they were positioned to clear the switch mounting screws under the cover. The extension is mounted with 1” of it above the existing switch cover and centered on the cover. The bottom of the extension is then flush with bottom of the upper horizontal stand rail. This arrangement allows the entire cover to be raised to turn the saw on, or to remove the screws that hold the switch in the cabinet. It’s easy enough to slip your hand under the cover and turn the saw on without completely raising the cover. The larger surface area of this cover makes it easy to blindly reach down and shut off the saw with out looking.
Original PDF Document:
safpwrsw.pdf
Posting comments is disabled.
Categories
Article Tags
- BT3x00 (71)
- bt3000 (5)
- bt3100 (2)
- diy (2)
- dust collection (11)
- Fence Attachments (12)
- General (5)
- Hand Tool Accessories (3)
- Hand Tools (14)
- Measuring & Layout (6)
- miter fence (2)
- Mobile BT3x00 (9)
- Mobile Tools (9)
- Other Reviews (4)
- Other Tools (5)
- Power Tool Accessories (28)
- Power Tools (75)
- rails (3)
- review (1)
- rip fence (4)
- safety (5)
- Sharpening (4)
- t-nut (3)
- wide table kit (2)
Latest Articles
by LCHIENSmall T-nut for the left side of BT3 rip fence or front of miter fence (Article Version)
11-30-2023, 04:00 PM
Item 1LAJ3 Mfr. Model 1LAJ3 (WW Graingers)...-
Channel: Jigs & Fixtures
12-07-2023, 12:19 AM -
by LCHIENAfter a bit more thinking, some universal T-bolts for the rip miter fence make more sense than fixture blocks.
So I took some 1/8th flat Aluminum 1.00 inches wide and cut 1-1/8" long to make a 1" x 1-1/8" rectangular plates; I used a short rip fence Block to space the length but not cause a kickback with the...-
07-09-2023, 02:37 PM -
by LCHIEN
Make the base from 1/8” aluminum bar, you can get 1.5”, 2”, and 3” at Lowes...-
05-24-2023, 09:55 PM -
by twistsolRipping thin strips can be accomplished in a number of ways, but this jig is the best I've found so far.
- There is no need to move the fence so every strip comes out exactly the same.
- It is incredibly easy to build
- It keeps your hands well away from the blade the whole time
- It keeps control of the strip you are ripping all the way through the cut and past the blade
- It doesn't interfere with the blade guard.
- You can cut strips from any length of stock
04-16-2023, 10:42 AM -
by LCHIENBT3000 tall rip fence
09-12-2021, 07:58 PM
Anyway the BT3000 tall fence is generally held on by the T-slots in the side of the rip fence. This is...-
10-20-2021, 03:27 AM -
by LCHIEN
I am finally going to use my BT3000 extension rails.
My objective is to have some easily attachable rail extensions rather than a full time wide BT3000 using two full rails taking up a lot of space and requiring table support under the right side as many do.
I just want some wider support but not to do full 4x8 sheets of ply... if I need that, I'll break the sheet down on some sawhorses with a circ saw and some guides.
I think I am going to cut my extension...-
08-14-2021, 11:32 AM -
The SawdustZone Statistics
Topics: 61,269
Members: 20,614
Active Members: 74
Welcome to our newest member, Havoily.
What's Going On
There are currently 9271 users online. 1 members and 9270 guests.
Most users ever online was 9,940 at 04:14 AM on Today.
Footer Ad
