Small T-Nut for the Left side of Rip Fence and Front of Miter Fence on BT3x saws.
- Created by: LCHIEN
- Published: 12-07-2023, 12:13 PM
- 0 comments
11-30-2023, 04:00 PM
Item 1LAJ3 Mfr. Model 1LAJ3 (WW Graingers)...Last edited by LCHIEN; 12-09-2023, 11:02 PM. -
Special DIY T-bolt for BT3000 Miter Fence, Rip Fence and Rails
- Published: 07-09-2023, 02:37 PM
- 3 comments
So I took some 1/8th flat Aluminum 1.00 inches wide and cut 1-1/8" long to make a 1" x 1-1/8" rectangular plates; I used a short rip fence Block to space the length but not cause a kickback with the...Last edited by LCHIEN; 01-25-2024, 01:27 AM. -
How to make a BT3x00 Rip Fence/Miter Fence fixture block for mounting jigs
- Published: 05-24-2023, 09:55 PM
- 3 comments
Make the base from 1/8” aluminum bar, you can get 1.5”, 2”, and 3” at Lowes... -
Another Thin Strip Jig
- Created by: twistsol
- Published: 04-16-2023, 10:42 AM
- 1 comment
- There is no need to move the fence so every strip comes out exactly the same.
- It is incredibly easy to build
- It keeps your hands well away from the blade the whole time
- It keeps control of the strip you are ripping all the way through the cut and past the blade
- It doesn't interfere with the blade guard.
- You can cut strips from any length of stock
BT3000/BT3100 tall rip fence simple using fence clamps
- Published: 10-20-2021, 01:24 PM
- 0 comments
BT3000 tall rip fence
09-12-2021, 07:58 PM
Anyway the BT3000 tall fence is generally held on by the T-slots in the side of the rip fence. This is...Last edited by LCHIEN; 10-29-2021, 02:21 AM. -
Extending rails/rail profiles
- Published: 08-14-2021, 11:32 AM
- 12 comments
I am finally going to use my BT3000 extension rails.
My objective is to have some easily attachable rail extensions rather than a full time wide BT3000 using two full rails taking up a lot of space and requiring table support under the right side as many do.
I just want some wider support but not to do full 4x8 sheets of ply... if I need that, I'll break the sheet down on some sawhorses with a circ saw and some guides.
I think I am going to cut my extension...Last edited by LCHIEN; 09-13-2021, 01:08 AM. -
Thingamajig
- Created by: Dedpedal
- Published: 02-02-2021, 10:24 AM
- 3 comments
Thingamajig
One of my early attempts at making mallets had me thinking how badly things could end up if my piece got away from me while cutting so I came up with this little jig sled to secure my work while cutting a 30° bevel on the end of the head.
A simple flat piece of 1/2” birch plywood with a fence squared to bot the sled and blade with gussets on one side and push type toggle clamps on the other. Right now I have to manually place the stop block with double sided tape but working on a t track... -
LarryG's Dual-Width Extension Wing
- Created by: LarryG
- Published: 02-01-2021, 02:10 PM
- 1 comment
Around the middle of 2006, I came up with an idea for an extension wing for my BT3100 table saw that solved some particular problems I had in my then-shop. The design worked well, and about a year later, on May 6, 2007, I started a thread on the old bt3central.com discussion forum and shared my design with the other members.
I called it the Dual-Width Extension wing, and you can see it here:
https://www.sawdustzone.org/forum/di...extension-wing
Almost immediately,... -
Shopmade sanding blocks
- Published: 12-17-2015, 09:41 PM
- 21 comments
Whilst cleaning up I found an old BT3central post by ejs1097 I printed out from a while back. I had forgotten about it.
I made some changes and whipped out a few in a couple of evenings.
What I liked about them was they hold the sandpaper tight and snug, the bought ones the paper works loose and sags and gets caught and tears.
Also easy and cheap. Also has a square end for sanding into corners and a radius to do curves. I did modify the block so it used thicker stock...Last edited by LCHIEN; 06-28-2022, 01:54 AM. -
BT3000 x 2 Frankensaw
- Created by: rickschuster
- Published: 03-10-2015, 10:30 PM
- 12 comments
Thanks to all of the great examples I saw on this forum, I decided that buying extension rails for my BT3000 would be silly when for less money I could find a used BT3000 to add to mine. Less money, and in addition to the rails I wanted, I had another complete saw, router table section, fence, sliding miter table, etc., and a far more useful saw overall. I really love some of the beautiful bases that some people have made for their Frankensaws, but I wanted to get the saws functioning to use for ... -
BT3000 Quick Fold Table and Manual
- Published: 06-29-2013, 02:54 PM
- 2 comments
I have attached the manual for those who requested it. I found this a useful accessory. Its a fairly heavy table about the width of the BT3000 and maybe just a bit deeper than the top of the BT3. The front attaches to the rear rail at two points of the BT3 and has a slightly beveled front to that the workpeices coming off the saw don't catch. There's a hinge right behind the rear rail which fastens to the bottom of the rear rail via T-slot using T-nuts and bolts (the hinge is articulated so... -
Zero Clearance Throat Plates with Levelers
- Created by: Stytooner
- Published: 11-27-2012, 01:14 AM
- 0 comments
Custom Zero-Clearance Throat Plates With Levelers It occurred to me almost instantly to tap out the 4 holes underneath the TP to a 10-24 thread. I had kind of cussed under my breath at the Ryobi factory for not tapping this there and adding the screws to my parts package. I also wondered why I hadn’t seen this adjustment in the manual. I guess that was not the their intended purpose. ... -
A Tenon Jig for the Ryobi BT3000
- Created by: staff
- Published: 11-27-2010, 12:50 AM
- 0 comments
Originally Posted by Highland Hardware in the category Traditional Table Saw Jigs - BT3000 Style A multi-purpose tenon jig like the one shown here is easy to build and easy to use on the BT3000. The jig is designed to ride on the rip fence, providing the capability for sliding movement accurately parallel to the blade as well as very easy positioning for centered or offset tenons, lap joints and bridle joints. The vertical tenoning fence can be removed and replaced with a right-angle cradle for splining miters, either individual pieces or assembled frames. An H-2 toggle clamp (see the clamp section of our main catalog) secures stock quickly and releases it instantly after cutting. ... -
BT3x00 Wide Ripping Jig
- Created by: big tim
- Published: 03-06-2008, 08:37 PM
- 6 comments
Without rail extensions the BT3x00 only rips up to a width of approximately 19". Unless of course you move the rails over, which means "re-calibrating" the rails afterwards. I put this jig together this afternoon and can now rip well beyond 24" in width. I shaped the bottom of the 3/4" thick slats so that the protrusion fit snugly in the upper slot of the front and rear rails. A shorter piece was screwed and glued to the end of those to raise the jig's fence so it will clear the auxiliary table. The ... -
JimD's Extension tables (with miter gauge slots)
- Created by: JimD
- Published: 01-19-2008, 02:06 PM
- 25 comments
One of the key disadvantages to the BT3000 and BT3100 is the very small surface areas to support wood being cut. This is obvious to anybody looking at these saws and probably contributes a lot to the fact that they did not sell at the volume their quality deserves. Fortunately, there is a relatively easy and inexpensive way to address this weakness - make yourself extension tables to increase the table size to whatever you need. I have used this construction method to make three tables so far. Th...
There are no articles in this category.
Please log in to your account to view your subscribed posts.
Categories
Latest Articles
by LCHIENSmall T-nut for the left side of BT3 rip fence or front of miter fence (Article Version)
Item 1LAJ3 Mfr. Model 1LAJ3 (WW Graingers)...-
Channel: Jigs & Fixtures
12-07-2023, 12:19 AM -
by LCHIENAfter a bit more thinking, some universal T-bolts for the rip miter fence make more sense than fixture blocks.
So I took some 1/8th flat Aluminum 1.00 inches wide and cut 1-1/8" long to make a 1" x 1-1/8" rectangular plates; I used a short rip fence Block to space the length but not cause a kickback with the...-
07-09-2023, 02:37 PM -
by LCHIEN
Make the base from 1/8” aluminum bar, you can get 1.5”, 2”, and 3” at Lowes...-
05-24-2023, 09:55 PM -
The SawdustZone Statistics
Topics: 61,290
Members: 20,633
Active Members: 68
Welcome to our newest member, Foster Kingston.
What's Going On
There are currently 6867 users online. 2 members and 6865 guests.
Most users ever online was 11,606 at 02:28 AM on 03-29-2024.
Footer Ad
