Model making And wood work.
- Created by: ArtworksIII
- Published: 05-22-2016, 06:01 PM
- 0 comments
To stay relevant in a Craft one only needs to make the most of his or her talents. The minds eye interprets the drawing the will of the crafts person takes the leap of faith. This is my 5th attempt at the model....
[ATTACH]21982[/ATTACH][ATTACH]21983[/ATTACH][ATTACH]21984[/ATTACH][ATTACH]21985[/ATTACH]Tags: NonePosting comments is disabled.
Categories
Article Tags
- BT3x00 (71)
- bt3000 (5)
- bt3100 (2)
- diy (2)
- dust collection (11)
- Fence Attachments (12)
- General (5)
- Hand Tool Accessories (3)
- Hand Tools (14)
- Measuring & Layout (6)
- miter fence (3)
- Mobile BT3x00 (9)
- Mobile Tools (9)
- Other Reviews (4)
- Other Tools (5)
- Power Tool Accessories (28)
- Power Tools (75)
- rails (3)
- remote control (1)
- rip fence (5)
- safety (5)
- Sharpening (4)
- t-nut (3)
- wide table kit (2)
Latest Articles
by LCHIENHere's how I do my Featherboard operations. As you know, Featherboards are spring boards meant to hold the workpiece against the fence snugly to ensure accurate rips while freeing both your hands for hand over hand and push stick smooth, even feeding of the workpiece to avoid burning and sawmarks.
The Feather board is the classic one that they suggest you make.... Mine was made 20+ years ago, apparently a 1x4 piece of pine wood with one end cut at 30 degrees. 15-16 inches long 3 to...-
Channel: SawdustZone Articles
04-15-2024, 06:19 PM -
by LCHIENI made a belly pan dust collection for my BT3000, using a commercially available, cheap dust pan from one of the woodworking supply houses with a 4" hose fitting.
It seems to work effectively very simple DC belly pan under BT3000. Not tightly fitting I wanted to allow air in to carry the dust to the DC, pulling on a close cabinet is not a good idea. SO the plywood sits on the stand, not screwed down or anything. So there's air coming in thru the ends and the Shroud dust port arc....-
03-16-2024, 04:37 PM -
by LCHIEN
With the small t-nut for the front of the rip fence and miter fence, I made a new stop block that can be used on both
https://www.sawdustzone.org/articles...nce-attachment
When used on the rip fence , it can set a stop for cross cutting fixed lengths off a piece against the miter fence without risking a kickback from continuous...-
02-17-2024, 01:43 AM -
by LCHIENSmall T-nut for the left side of BT3 rip fence or front of miter fence (Article Version)
11-30-2023, 04:00 PM
Item 1LAJ3 Mfr. Model 1LAJ3 (WW Graingers)...-
Channel: Jigs & Fixtures
12-07-2023, 12:19 AM -
by LCHIENAfter a bit more thinking, some universal T-bolts for the rip miter fence make more sense than fixture blocks.
So I took some 1/8th flat Aluminum 1.00 inches wide and cut 1-1/8" long to make a 1" x 1-1/8" rectangular plates; I used a short rip fence Block to space the length but not cause a kickback with the...-
07-09-2023, 02:37 PM -
by LCHIEN
Make the base from 1/8” aluminum bar, you can get 1.5”, 2”, and 3” at Lowes...-
05-24-2023, 09:55 PM -
The SawdustZone Statistics
Topics: 61,285
Members: 20,628
Active Members: 64
Welcome to our newest member, harveywall.
What's Going On
There are currently 5153 users online. 2 members and 5151 guests.
Most users ever online was 11,606 at 02:28 AM on 03-29-2024.
Footer Ad
